> Apexi avcr boost settings
post Dec 26, 2014 - 2:50 PM
hotgt4
Joined Jul 21, '13
From Gisborne New Zealand
hey guys and girls I've got an apex I avcr boost controller what are the recommended boost settings at 0.9 bar ? Thanks
Rip Paul walker
'' DUDE I ALMOST HAD YOU ''
post Dec 30, 2014 - 9:52 PM
mkernz22
Joined May 10, '10
From MA
What do you mean by boost settings?
Being that it's a ST205, it can handle 1 bar = 14.5psi no problem
post Dec 31, 2014 - 12:25 AM
hotgt4
Joined Jul 21, '13
QUOTE (mkernz22 @ Dec 30, 2014 - 10:52 PM) *
All the settings like Ne point and what time your turbo should kick in etc how do you set that up at 12 psi it's been in the car ever since I bought my st205 I've never played with it the settings thanks lol
This post has been edited by hotgt4: Dec 31, 2014 - 12:28 AM
Rip Paul walker
post Jan 4, 2015 - 1:43 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (hotgt4 @ Dec 31, 2014 - 12:25 AM) *
Your turbo just starts to spool at a certain rpm range, but also depends on the percentage of throttle input.
A boost controller just limits how much or little your turbo will make.
You can probably find a PDF online if you search around on Google.
post Jan 17, 2015 - 1:24 PM
hotgt4
Joined Jul 21, '13
QUOTE (mkernz22 @ Jan 4, 2015 - 1:43 AM) *
Yeah mate thanks
Ive done a bit of lurking around on google etc and signed up with gt40c.net seems like a good website, they have a pdf file wich tells you what setting to setting to set your Apexi avcr boost setting cheeers
Rip Paul walker
post Jun 25, 2015 - 2:08 AM
hotgt4
Joined Jul 21, '13
I played with my apexi avcr in the weekend, And i noticed on 1.1 bar im boosting at 14.5 psi is this normal or should it be more at 1.1 bar ?
At 0.90 its 12 psi, ive got an after market exhaust, down pipe , and pod filter,
Rip Paul walker
post Jun 25, 2015 - 10:10 AM
cardshark525
Joined Jan 12, '09
From State College, PA
1 bar is 14.5 psi.
In as much as 1 mile is 1.62 km.
Your mods are irrelevant when it comes to a standardized unit of measurement for atmospheric pressure, being converted to a different measurement for pressure.
This post has been edited by cardshark525: Jun 25, 2015 - 10:14 AM
post Jun 30, 2015 - 8:27 AM
texasnick
Joined Feb 23, '10
From Vancouver, BC
QUOTE (hotgt4 @ Jun 25, 2015 - 2:08 AM) *
Should be right around 16-17 psi (1.1 bar). You need to adjust the duty slowly up until it reaches
This is from alltrac.net Seems to work well for most...
Apexi AVC-R settings for 0.9 Bar and 1.1 bar
This will give you a basic set up for your APEXi AVC-R boost controller...after this its up to you to play/adjust to suit your car...based on a 3sgte running more or less standard everything.
Settings Section
Setting [A] 0.9 Bar
Boost /Duty Cycle
Bst = 0.90kg/cm2
Duty = 52% - You will probably need to adjust this to suit your car
NE Point
NE1 = 3000
NE2 = 3500
NE3 = 4000
NE4 = 4500
NE5 = 5000
NE6 = 5500
NE7 = 6000
NE8 = 6500
F/B Speed
1S = 5
2N = 5
3R = 5
4T = 5
5T = 5
Learn Gear
1S = x
2N = x
3R = x
4T = x
5T = x
Start Duty
Set to 0% in all
Setting [B] 1.1 Bar
Boost /Duty Cycle
Bst = 1.10kg/cm2
Duty = 60% - You will probably need to adjust this to suit your car
NE Point
NE1 = 3000
NE2 = 3500
NE3 = 4000
NE4 = 4500
NE5 = 5000
NE6 = 5500
NE7 = 6000
NE8 = 6500
F/B Speed
1S = 5
2N = 5
3R = 5
4T = 5
5T = 5
Learn Gear
1S = x
2N = x
3R = x
4T = x
5T = x
Start Duty
Set to 0% in all
Etc settings
Car Select
Cyl = 4
Spd = 5
Throttle = / (arrow pointing up to the right)
Sensor Select
Number one (1)
Gear Jdge
1st = 120
2nd = 075
3rd = 050
4th = 035
5th = 025
N/S = 255
Graph Scale
BS = 2.0kg/cm2
Ne = 8000 RPM
Sp = 300km/h
Monitor
3 Channel
1 Bst
2 Rev
3 Thr
After this you can start adding one or two % to the start duty in 1st and 2nd grears to get the turbo spooling quicker.....(its more difficult to reach full boost quickly in 1st and 2nd gear even using just a boost controller to control things and bypassing the standard systems)
This post has been edited by texasnick: Jun 30, 2015 - 8:28 AM
post Jun 30, 2015 - 12:43 PM
Nial
Joined Aug 25, '08
From England
For the "start duty" add maybe 3% in first and 1.5% in second, it just gives those gears boost a bit of a head start and gets you on full boost slightly quicker.
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
Lo-Fi Version Time is now: December 1st, 2024 - 11:26 PM
