gt4 st205 transmission awd to fwd |
Dec 30, 2014 - 10:13 AM |
Enthusiast Joined Nov 14, '14 From greece Currently Offline Reputation: 0 (0%) |
I bought 3sgte swap with gt4's transmission can work only on the front only ?or I need to block somehow the rear differential because someone told me that will slip
Jan 2, 2015 - 2:02 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
You would have to remove the center housing, replace the differential, and install an e153 cover plate to convert the awd trans to fwd. Using the awd trans with just the front axles will destroy the viscouse coupler
Jan 2, 2015 - 9:41 PM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
u cant mount it without takeing the transfer case off anyway. exhaust would be in the way. so no u can not. u must!!!! just cheaper for u to get an e153 than go thru the trouble of taking the case off and get a plate.
Lo-Fi Version | Time is now: November 29th, 2024 - 5:07 PM |
