4 Pages V  < 1 2 3 4 >
> doing a 3S-GTE swap
post Jan 12, 2015 - 4:33 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
Thanks Manny, ill do another read on your thread.
OFF TOPIC, have you guys seen this?
https://www.youtube.com/watch?v=7hCPODjJO7s
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 12, 2015 - 4:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
Smaay, 3S-GTE??? *looks outside for the Seven Horesemen* At least it makes more sense than a BEAMS. tongue.gif
2001 Miata LS 5-speed
post Jan 12, 2015 - 10:52 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Box @ Jan 12, 2015 - 1:48 PM) *
lol its not going in my car lol. And ill never put a BEAMS in one of my cars smile.gif
:::::update:::::
finally got the transmission separated. i used these guys
i was able to get a wrench on it and get the bolt started. it was a real pain to get it out. got the intake manifold off and harness free. so many connectors broke taking them off.
all those VSV's under the manifold, i can delete those correct? i am going to delete all those water lines to the IAC too.
post Jan 12, 2015 - 10:55 PM
celicakitten
Joined May 30, '12
From CA/NV
QUOTE (Box @ Jan 12, 2015 - 5:48 PM) *
2004 Celica GT-2zz w/6-speed swap
1999 Celica GT-3sgte swap
1993 Celica All-Trac
1997 Celica ST/Limited-rip
1993 Celica GT-rip my first love
post Jan 12, 2015 - 11:45 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Jan 13, 2015 - 12:13 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
another thing i noticed in the ECU diagram. there is a pin for EGR, ECU pin C6. WTH?
Also what is everyone doing for AC? i was planning on using the GT compressor. i see on the ST205 ECU diagram AC1 and ACT as normal, but there is also an ATS signal going to the AC amplifier. the GT does not have this. What to do?
This post has been edited by Smaay: Jan 13, 2015 - 10:07 AM
post Jan 13, 2015 - 12:30 PM
bsamps4
Joined May 16, '10
From Raleigh
I have a 3s compressor if you need it, but to my knowledge you don't need to change anything to get the 5s compressor to work.
post Jan 13, 2015 - 2:07 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
thanks the engine came with a compressor, i just wanted to use the GT system since I never opened it
post Jan 14, 2015 - 3:45 PM
Im not using any signals from ecu to ac in the 2gr. It will suck
post Jan 15, 2015 - 12:46 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
so i took the 205 harness apart today. well what i had, i discovered that I dont think a 205 harness needs to be extended. open the harness up and re-route the leads going to the ECU and body harness.
im sure a complete harness might need some wires adjusted but with what I have, i might get lucky.
post Jan 15, 2015 - 9:00 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
ok here is a picture of the harness with all the loom removed.
the run going down to the bottom left of the picture leads to the ECU. in the top left is where it was cut. They cut off the fuse and EA1, positive battery, coil, and igniter. they also cut off my fuel rail.
So what im hoping is that i can just rotate the wiring so that it will run along the injectors and then come down the right side to the normal firewall location. Ill salvage wiring from a GT harness for what i need and maybe have to extend a few wires. This might not be that bad at all
post Jan 15, 2015 - 3:43 PM
bsamps4
Joined May 16, '10
From Raleigh
On the right track! Still doesn't look like a picnic.
post Jan 16, 2015 - 10:59 AM
luka
Joined Jul 23, '08
From Hawaii
awesome work!
I need to get my swap going too
post Mar 23, 2015 - 3:34 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
for the code 54 fix, what is the wattage needed for the 1K resistors? will 1/4 watt be enough? 1/2? or 1 watt?
post Mar 23, 2015 - 4:01 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just go with what's biggest that'll easily fit. Higher the wattage the more it can dissipate without catching fire. Catching fire is never fun.
post Mar 23, 2015 - 5:15 PM
1/2 watt should be fine.
post Mar 23, 2015 - 9:52 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Box @ Mar 23, 2015 - 2:01 PM) *
very true
QUOTE (Batman722 @ Mar 23, 2015 - 3:15 PM) *
awesome, thanks Dustin!!!
post Mar 29, 2015 - 7:16 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
Tore the engine apart, its a good thing I did. the rod bearings showed serious wear. This is exactly why I dont support JDM engines, you never know what you are going to get. You spend more money tearing it down and rebuilding it with new parts.
the bearings on the left were under the rod, the right were under the rod cap. this is a sign of poor oil changes, more than factory boost, or detonation. I replaced all the bearings with ACL.
Im doing a build thread much like the 7A-FE build i wrote. step by step building a 3S-GTE.. it will have its own thread.
post Mar 29, 2015 - 7:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Mar 29, 2015 - 7:33 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah im sure they abuse the hell out of them, knowing they have to be changed every 60K KM
Lo-Fi Version Time is now: November 28th, 2024 - 11:00 PM
