4 Pages V  « < 2 3 4
> doing a 3S-GTE swap
post Jun 14, 2015 - 1:37 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
it had provisions for an anti lag but it was never used. so the nipple on the intercooler is for AC idle up, I can just cap that.
still looking for an answer on the stock BOV, there are 2 nipples on it. which one needs to be used?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 14, 2015 - 11:06 AM
cardshark525
Joined Jan 12, '09
From State College, PA
http://www.6gc.net/forums/index.php?showtopic=81978
Last pic is about the most detailed information I could find on it.
Another pic (happens to be my engine lol):
http://s82.photobucket.com/user/supershann...st2058.jpg.html
This post has been edited by cardshark525: Jun 14, 2015 - 11:11 AM
post Jun 15, 2015 - 7:45 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
thanks for the pics but they really didnt help much.
The first link does help a little.
post Jun 15, 2015 - 6:21 PM
the pic you posted is the anti lag valve. the stock BPV is connected to the airbox.
the level sensor just needs the 2 wires bridged.
the relay mod at the ecu is the only way to kill the code 54 at the ecu, you need the water pump plug to do the resistor mod.
post Jun 15, 2015 - 7:27 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (presure2 @ Jun 15, 2015 - 4:21 PM) *
so i should just remove this valve all together, I can put a BOV in this position. I didnt get the stock BPV with the engine
Yep did both of these, i have beat code 54, thanks again
So far i think i can just cap the nipple coming off the intercoler, the 2 hard lines on the manifold for anti lag that go into the valve need to be capped. install BOV where the anti lag valve is.
post Jun 28, 2015 - 9:42 AM
QUOTE (Smaay @ Jun 15, 2015 - 8:27 PM) *
yup, you can install the bov where the anti lag valve is.
everything you said sounds correct to me jeff.
sorry i havent replied sooner, i dont hit t he site very often anymore. best to contact me on facebook directly.
post Jun 29, 2015 - 10:17 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
Thanks Manny.
post Aug 16, 2015 - 11:06 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
just an update, car is running strong and no code 54. no code at all actually. I still like my V6 better
post Oct 8, 2015 - 1:17 AM
chacha
Joined Dec 29, '05
From So-Cal
i have the jdm 3sgte from an st205, have the uk spec egr assembly and all, where the red plug (VSV) with the male adapter, which wire connects here, or because it is a euro egr for the st205 and i have a jdm that the wire won't exist to connect...
This post has been edited by chacha: Oct 8, 2015 - 4:14 AM
4 Pages V  « < 2 3 4
Lo-Fi Version Time is now: November 25th, 2024 - 7:43 AM
