> WTB: ignition coil for 96 GT
post Jan 8, 2015 - 8:42 PM
FWD-3SGTE
Joined Feb 8, '07
In need of an ignition coil for a 96 GT with the 2.2 5SFE
post Jan 8, 2015 - 8:58 PM
Arturio55
Joined Mar 6, '13
From New jersey
Anyone know if the 7afe and 5sfe coil is interchangeable? If so, I have one
QUOTE (Azncelica @ Mar 4, 2012 - 11:43 PM) *
I started with what I know to do, I swap engine into my car, I knew it was too much work to make it a AWD. I kept it FWD. Went to take a crack at doing the wiring conversion. Than, I realize, shoot, this is out of my league.
post Jan 8, 2015 - 9:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
They're not. Look at RockAuto, eBay, or Amazon for the best prices on one. I was looking for someone else the other night on RockAuto and they weren't terribly expensive if I recall correctly.
2001 Miata LS 5-speed
post Jan 8, 2015 - 9:49 PM
i thinks me haz guan, ill see tomorrow.
post Jan 9, 2015 - 8:11 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
If you need an ignitor I've got one I've never even used I'll sell you for what I bought it for $85 and free shipping.
"As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
post Jan 10, 2015 - 12:47 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
also is the same parts from a 4 cylinder Camry '90-97ish, depending on when they switched from a dizzy to coil packs. But there are a dozen of them in Each salvage yard in town.
Bust a Deal; Face the Wheel.
post Jan 11, 2015 - 12:01 PM
FWD-3SGTE
Joined Feb 8, '07
I have the igniter, just need a coil. I'm not sure which ones are interchangeable. I'm using a 3SGTE coil now and it works (doesn't fit the coil wire well) but getting misfire code due to it I presume..
post Jan 11, 2015 - 1:54 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just buy a new one for $20 from RockAuto, save some headaches.
post Jan 13, 2015 - 7:06 PM
FWD-3SGTE
Joined Feb 8, '07
I don't have rockauto around here but regardless, I figured one from a auto parts store would be close to $100+..
I'll look into that option.
post Jan 13, 2015 - 7:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Jan 13, 2015 - 7:19 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
do a compression test. it might not be the coil. dont spend money that wont fix the problem.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 13, 2015 - 10:02 PM
Box
Joined Feb 23, '12
From Warrior, AL
That and the cap and wires.
See this is the beauty of OBDI, it doesn't trigger for every little thing. tongue.gif
This post has been edited by Box: Jan 13, 2015 - 10:04 PM
post Jan 14, 2015 - 12:27 PM
post Jan 14, 2015 - 4:32 PM
FWD-3SGTE
Joined Feb 8, '07
I need a coil anyway. Cap, rotor and wires are brand new OEM.
Lo-Fi Version Time is now: November 22nd, 2024 - 7:47 PM
