> Spring Coil Bind, also known as spring sag
post Jan 13, 2015 - 2:57 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
So i purchased these TRD front Springs 48131-ST001(@ 4.1kg spring rate) for my superstrut conversion. So i didnt see rust when i bought them until i received them. So now that i've learned about coil bind/sagging from sport springs. You wouldn't think it would happen to good quality TRD Springs. pics as follow. so basically what can i do? i've read from an Subaru Forum that you can definetly tell if the springs are bad unless you get the manufacture specs of the distance between each coil. I've read that EIBACH and TRD springs are one in the same, is this true?? the length of TRD spring measure in @ 24.5 cm and claim a 1 inch drop and Stock ST205 springs are 30.5cm @ 2.5kg spring rate.
This post has been edited by BonzaiCelica: Jan 14, 2015 - 10:46 PM
post Jan 13, 2015 - 4:28 PM
Box
Joined Feb 23, '12
From Warrior, AL
Are they real TRD springs? I'm fairly sure they're supposed to have "TRD" throughout the spring, of course they could be on the other side from what the pictures show. Not sure about TRD, Eibach, or whoever but Tein warrants against anymore than 5mm of sag.
2001 Miata LS 5-speed
post Jan 13, 2015 - 4:43 PM
BonzaiCelica
Joined Apr 24, '08
cmon bro how long have i been on the forums now??
post Jan 13, 2015 - 4:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
I know, that's why I said what I did about them being on the other side of what the pictures were showing. tongue.gif Anyway there shouldn't be more than a few mm of sag I'd think.
An inch is 2.54 cm, so it would seem something is off?
post Jan 14, 2015 - 2:02 AM
Rusty
Joined Nov 5, '07
From New Zealand
Aren't they 4.2kg the fronts? Where did you get your spring rates from, as they are a bit off?
The previous owner must have done some interesting driving or had a bit of weight?
post Jan 14, 2015 - 2:26 AM
Box
Joined Feb 23, '12
From Warrior, AL
The previous user was a sumo wrestler that drove through the snow whenever possible, it makes sense so go with it. tongue.gif
post Jan 14, 2015 - 2:13 PM
BonzaiCelica
Joined Apr 24, '08
ah yes rusty correction i had it wrong but you were slightly off too(i corrected the first post). I assumed it was 3.9kg because it was superstrut, but they were actually mcpherson springs on his superstrut suspension(perhaps his local parts store he bought them from didnt have the specific trd superstrut springs in stock and he just settle for mcpherson TRD spring rate which are .2kg softer
So correction the TRD front springs i have are 4.1kg
rusty its the thread you created! : http://www.6gc.net/forums/index.php?showtopic=89725
post Jan 16, 2015 - 4:52 PM
Rusty
Joined Nov 5, '07
From New Zealand
I went off part numbers, and then did fresh acaluation, and rounded the last number up too much, though your ST205 springs spring rate are a bit low still see my thread
post Jan 16, 2015 - 7:41 PM
Common man, how long do you expect springs to last like brand new? Its been 15 to 20 years
post Jan 16, 2015 - 9:06 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (njccmd2002 @ Jan 16, 2015 - 6:41 PM) *
post Jan 17, 2015 - 2:35 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (njccmd2002 @ Jan 16, 2015 - 7:41 PM) *
ive heard some springs having million mile warranty.
haha just saw this after i sent you the pm
post Jan 17, 2015 - 9:40 AM
gsla72
Joined Oct 24, '13
http://www.toyotaracing.com/trd/
Looks like a 12 month/12,000 mile warranty as of right now.
post Jan 17, 2015 - 11:49 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
The end of the coil touching the next coil is normal since it's not a full coil being compressed, make sense?
Lo-Fi Version Time is now: November 25th, 2024 - 6:41 PM
