> s54 quaife, can anyone verify?
post Feb 5, 2015 - 1:56 PM
Arturio55
Joined Mar 6, '13
From New jersey
Bought a s54 tranny from a guy in Minnesota. He says it has a quaife. It definitely has an lsd, just want someone familiar with their fair share of differentials to confirm it is in fact a quaife.
If nobody can tell, how hard would it be to crack open that side of the tranny so i can look for a part number or insignia? Not familiar with tranny guts so i would rather not mess anything up.
Any other advice or opinions welcome. Pics below.
QUOTE (Azncelica @ Mar 4, 2012 - 11:43 PM) *
I started with what I know to do, I swap engine into my car, I knew it was too much work to make it a AWD. I kept it FWD. Went to take a crack at doing the wiring conversion. Than, I realize, shoot, this is out of my league.
post Feb 5, 2015 - 2:16 PM
Rusty
Joined Nov 5, '07
From New Zealand
What type of Lsd is the quaife? Mechanical clutch type? As this is what my TRD LSD is and it has no bars just a gap like yours
post Feb 5, 2015 - 3:23 PM
Arturio55
Joined Mar 6, '13
From New jersey
QUOTE (Rusty @ Feb 5, 2015 - 2:16 PM) *
The quaife is a helical, mechanical gears.
post Feb 5, 2015 - 6:21 PM
enderswift
Joined Jul 12, '08
I just installed a helical into an s54.
Taking apart the trans is not really a good way to go about checking. There's a lot that has to be removed before your reach the diff. I documented a good portion of my rebuild so you might get some answers there:
http://www.6gc.net/forums/index.php?showto...0487&st=340
I would just send a picture of the axle hole to quiafe and ask them
post Feb 5, 2015 - 6:41 PM
enderswift
Joined Jul 12, '08
Found some stuff from some researching I did a year ago:
Early S54 helical LSD
Late Model S54 helical LSD
Common S54 open differential
post Feb 6, 2015 - 11:21 AM
Arturio55
Joined Mar 6, '13
From New jersey
QUOTE (enderswift @ Feb 5, 2015 - 6:21 PM) *
Thanks, i didnt even think about asking quaife themselves lol. Still not sure if they know what each diff looks like installed tho kindasad.gif ill try
post Feb 7, 2015 - 3:06 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
this pic is so deceiving, this is exactly what the MR2 turbo with LSD trans looks like
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 7, 2015 - 10:02 AM
enderswift
Joined Jul 12, '08
I know, the e153 viscous diff has a bar just like the s54 open diff. Except the e153 has a thicker bar. This caused a TON of confusion on the forums over the years..
post Feb 8, 2015 - 7:10 PM
rdyzz
Joined Dec 27, '11
From minnesota
Thats my transmission I sold you, it is a quaife, pull the mechanical speedometer drive that I have on it and take a peek inside, do not open it up unless you know the torque specs and your familiar with working on manual trans. The one I used is the one for the 2zzge transmission which is the same parts number as the s54.
QUOTE (Arturio55 @ Feb 5, 2015 - 2:56 PM) *
post Feb 9, 2015 - 3:07 AM
Rusty
Joined Nov 5, '07
From New Zealand
Whats this 'Early S54 helical LSD' you are referring to?
Lo-Fi Version Time is now: February 23rd, 2025 - 10:51 AM
