ecu pinout explanation |
Feb 8, 2015 - 7:50 PM |
Enthusiast Joined Sep 9, '08 From Jamaica Currently Offline Reputation: 1 (100%) |
Hello,
i been wiring in some new equipment and from looking on the ecu pinout for the st205 i saw the following relating to the distributor and would like some explanation on eachs purpose: G2 - Distributor G1 - Distributor NE - Distributor G- - Distributor what does each do.... i imagine the G- is a ground or negative signal but what is the function of the others? also, can IGF be used to provide the rpm reading for the car? |
Feb 8, 2015 - 9:11 PM |
Hello, i been wiring in some new equipment and from looking on the ecu pinout for the st205 i saw the following relating to the distributor and would like some explanation on eachs purpose: G2 - Distributor G1 - Distributor NE - Distributor G- - Distributor what does each do.... i imagine the G- is a ground or negative signal but what is the function of the others? also, can IGF be used to provide the rpm reading for the car? nvmd, figured it out |
Lo-Fi Version | Time is now: November 26th, 2024 - 8:49 PM |
