Climate control cable location on control lever. |
Feb 12, 2015 - 11:25 PM |
Enthusiast Joined Nov 20, '14 From Central Texas Currently Offline Reputation: 0 (0%) |
I removed my climate control from my console to facilitate carpet replacement. I managed to disconnect the cables from the inside mounting bracket and holes. I could not find the paper I wrote the location of the cables on, so I don't know which hole the black cable goes in and which hole the blue cable goes in. I need to find out where the cables go on the lever. Can someone help me with the locations? I did search, but only found info re the disconnect under the hood and under the dash.
Thanks in advance |
Feb 13, 2015 - 1:36 PM |
Enthusiast Joined May 10, '14 From Tulsa, OK Currently Offline Reputation: 5 (100%) |
I am at work so when I get home I have one pulled from my car and will take a picture and send it to you or describe it to you. So if you can wait till this evening I can look up for you. On the othersider/engine side the black one is the longer one and goes in the engine bay. The blue one goes near the accelarator pedal.
Feb 13, 2015 - 2:16 PM |
Enthusiast Joined Apr 15, '13 From Winnipeg, MB, Canada Currently Offline Reputation: 14 (100%) |
The blue one goes here behind the center console, to the right of the pedals.
The black one comes through the firewall and right here, behind the engine. -------------------- 2007 Impreza 2.5i - Daily
1994 Camry - Sold 1994 Celica - Sold :( Click here to see my progress thread! |
Feb 13, 2015 - 3:35 PM |
Feb 13, 2015 - 6:55 PM |
Thanks Norberto. I just got home from work.
Feb 14, 2015 - 2:37 PM |
I removed my climate control from my console to facilitate carpet replacement. I managed to disconnect the cables from the inside mounting bracket and holes. I could not find the paper I wrote the location of the cables on, so I don't know which hole the black cable goes in and which hole the blue cable goes in. I need to find out where the cables go on the lever. Can someone help me with the locations? I did search, but only found info re the disconnect under the hood and under the dash. Thanks in advance Wow, what a difference a little knowledge makes. I again removed the climate control module from the console after disconnecting the 2 cables and attaching a wire to the black one for retrieval. I did have them reversed on the module and it was a simple matter to swap positions this time. Thanks again for the assistance. |
Feb 14, 2015 - 2:39 PM |
guys, sorry my responses are taking so long to get posted. I guess I am still a probie.
Lo-Fi Version | Time is now: November 27th, 2024 - 6:01 AM |
