> Tire change question / problem?
post Feb 25, 2015 - 2:10 PM
Selly_Kuhman
Joined May 13, '12
From US- NY
What does this mean?
I have a manual transmission on a 95 GT. I got flat the other day and when I took my tire off (car was running and kept in neutral to keep it heated since it was 20 degrees out) the pegs where I would put my spare tire on were slowly rotating. When I turned the car off it stopped. Is the supposed to happen? If not what is causing this?
post Feb 25, 2015 - 2:50 PM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (Selly_Kuhman @ Feb 25, 2015 - 3:10 PM) *
Nothings wrong with it, its normal when there is no load on the hubs for the axle to spin slowly. When there is a load on the hubs and car is in neutral it wont do anything.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Feb 25, 2015 - 3:23 PM
Selly_Kuhman
Joined May 13, '12
From US- NY
QUOTE (igpx12 @ Feb 25, 2015 - 2:50 PM) *
If that's the case, then it's safe to say if I took my other front side wheel off it would spin slowly at a constant rate as well? Also if I removed my rear wheels, would they be still since I have a FWD?
post Feb 25, 2015 - 5:39 PM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (Selly_Kuhman @ Feb 25, 2015 - 3:23 PM) *
That would be the case with all of it, if you just jack the front up the wheels will start to spin slowly in neutral unless you put some force against it. The rear wheels are just hubs with bearings, no drive mechanisms, so they wouldn't move unless you move them by hand.
post Feb 25, 2015 - 6:34 PM
Selly_Kuhman
Joined May 13, '12
From US- NY
Thanks for clearing that up for me. I guess ive never had my car running before when changing a tire on the front end.
Lo-Fi Version Time is now: December 4th, 2024 - 10:30 AM
