> size of back up lamp switch
post Mar 10, 2015 - 7:06 PM
Arturio55
Joined Mar 6, '13
From New jersey
My reverse lights haven't been working since i got the car. Already replaced bulbs, no luck. I have an extra s54 that i can take a switch out of, just need to know what size socket i have to buy
QUOTE (Azncelica @ Mar 4, 2012 - 11:43 PM) *
I started with what I know to do, I swap engine into my car, I knew it was too much work to make it a AWD. I kept it FWD. Went to take a crack at doing the wiring conversion. Than, I realize, shoot, this is out of my league.
post Mar 10, 2015 - 7:26 PM
Box
Joined Feb 23, '12
From Warrior, AL
2001 Miata LS 5-speed
post Mar 10, 2015 - 7:34 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Box @ Mar 10, 2015 - 8:26 PM) *
My best guess would be that you need a deep 17mm socket.
Most things are 10, 12, 14, or 17mm
post Mar 10, 2015 - 7:54 PM
Arturio55
Joined Mar 6, '13
From New jersey
QUOTE (mkernz22 @ Mar 10, 2015 - 8:34 PM) *
No its at least 22mm. maybe bigger.
my biggest sockets wont fit (19mm and 15/16)
post Mar 10, 2015 - 9:28 PM
Box
Joined Feb 23, '12
From Warrior, AL
Could be 22mm, as that was the size for the fill plug if I recall correctly.
post Mar 10, 2015 - 10:30 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
the drain plug on my s54 is a 15/16", which is 24 mm. I went to Sears just to find a 6 point box end to be sure I don't round off my new drain and fill plugs smile.gif
http://extension.missouri.edu/webster/wrench-chart.aspx
anything bigger is usually the 31mm(or is it 32?) like is used for the spark plug tubes, oil cooler, and axle hub me thinks.
Bust a Deal; Face the Wheel.
post Mar 11, 2015 - 12:01 AM
Arturio55
Joined Mar 6, '13
From New jersey
Okay, ive taken off both the fill and drain plug on my transmission. Not the same size as reverse switch.
I have all socket sizes from 3mm up til 19mm and 15/16. NONE of them fit.
i also have a 30mm axle nut socket and its too big.
so its gotta be between 20 and 29mm.
This post has been edited by Arturio55: Mar 11, 2015 - 12:02 AM
Lo-Fi Version Time is now: January 10th, 2025 - 5:00 PM
