good place to ground a wire?(interior) |
Jan 28, 2003 - 5:56 PM |
Enthusiast Joined Oct 4, '02 Currently Offline Reputation: 0 (0%) |
I'm looking for a convenient spot to ground a wire. Somewhere near the driver's footwell would be great. Something as easy as grounding to an existing screw would be perfect.
Thank you! |
Jan 28, 2003 - 6:07 PM |
Enthusiast Joined Oct 25, '02 From London- England Currently Offline Reputation: 0 (0%) |
There's a plastic trim panel in the drivers footwell (side next to thedoor "scuff/ kick panel).You can remove the plastic scuff panel and then remove this particular panel which sits just to the side of the fuse box panel.Behind here are a number of wire looms, you'll find a large earth/ground return wire (black)
which is fixed with a screw to the chassis. Try it if you can't find an easier ground point. |
Lo-Fi Version | Time is now: November 25th, 2024 - 2:26 AM |
