AC wont stay on Help!, Help! |
Mar 16, 2015 - 10:48 PM |
Enthusiast Joined Jul 13, '14 From Pasadena, CA Currently Offline Reputation: 0 (0%) |
So the problem is, when i turn on my AC is only stays for about 3 seconds and then it just shuts off. I can feel it blowing cold air and I just replaced the AC relay, so could it be a problem with the compressor or some kind of sensor??
Forgot to mention that the light also blinks off and on before it shuts down. Any help is appreciated! This post has been edited by thatSt204guy: Mar 17, 2015 - 5:33 AM |
Mar 17, 2015 - 3:47 PM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
Low pressure cut off switch. It means you're low on refrigerant.
There is also a sight glass on top of the filter/dryer(small cylinder near bottom left of radiator). When you're charged up good you won't see any bubbling in the sight glass. This post has been edited by VavAlephVav: Mar 17, 2015 - 3:50 PM -------------------- Bust a Deal; Face the Wheel.
Mar 17, 2015 - 3:54 PM |
Is there any other problem you can think of because I had it recharged and checked for leaks last week??
Mar 17, 2015 - 4:33 PM |
I'd call the place you had it done and explain what's going on. They should offer to take care of it.
Mar 17, 2015 - 6:38 PM |
It could even be overcharged and the high pressure cut out, especially if there's a blockage in the system like a plugged orifice tube.
Mar 17, 2015 - 10:45 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
Is the AC button blinking after it shuts off?
-------------------- God made man....
Everything else... Made in China |
Mar 18, 2015 - 1:30 AM |
Well it was professionally recharged but is there a way to let pressure out without letting out all the gas?
I also found this http://www.6gc.net/forums/index.php?showtopic=74725&st=0 old thread and I will be going through their suggestions but if none of them work I will be back here for more help Thankx again for the suggestion and help!! |
Mar 18, 2015 - 1:32 AM |
Mar 18, 2015 - 10:15 AM |
I've got a complete AC info thread here
http://www.6gc.net/forums/index.php?showto...arge+your\ It would be best to actually have some gages to measure the refrigerant pressure before you just let any out. If you were to release some the best way is to open the valve and release it from the high side port in the front of the car. But you need a set of refrigerant gages to do that. And really imo there are lots of "professional " shops who still don't know how to do the AC right. Or better still they figured they'd not do it right so you'd have to come back and spend some more money. I freakn hate dumb****s like that. -------------------- Bust a Deal; Face the Wheel.
Mar 18, 2015 - 6:48 PM |
Ok after looking at the thread I would probably just have a shop do it looks pretty complicated and i dont have the tool for it either.
Mar 19, 2015 - 2:11 PM |
Is the AC button blinking after it shuts off? yes, it start blinking after it shuts off My guess it would be more related to the AC compressor -------------------- God made man....
Mar 20, 2015 - 4:56 PM |
I was looking behind the glove box and i found that this plug is not plugged in. It this the problem that I'm running into. If it is I can't find the plug that is supposed to be there.
(this isn't my picture i just took off the net) I'm looking for the plug circled in red. Is the AC button blinking after it shuts off? yes, it start blinking after it shuts off My guess it would be more related to the AC compressor would recommend just buying a new AC compressor? This post has been edited by thatSt204guy: Mar 20, 2015 - 6:10 PM |
Mar 21, 2015 - 1:03 AM |
I'd recommend trying to find somebody you can trust to look at it and at least figure out what's wrong with it for sure.
Without actually being there it is hard to really know for sure. I don't think you want to just go out and buy a new compressor just yet. -------------------- Bust a Deal; Face the Wheel.
Mar 23, 2015 - 10:16 AM |
I'd recommend trying to find somebody you can trust to look at it and at least figure out what's wrong with it for sure. Without actually being there it is hard to really know for sure. I don't think you want to just go out and buy a new compressor just yet. Yeah don't buy the compressor until the problem is professionally diaganosed. You should take it to a shop and have them look at it first before you decide to buy anything. -------------------- God made man....
Mar 24, 2015 - 8:07 PM |
I was taking out the ac compressor and I found this sensor on it, but I don't know what it's for. Does anyone know??
And would anyone know the part number for this? |
Mar 24, 2015 - 8:33 PM |
do you guys happen to know how much refrigerant our cars should take because I had the system drained today by the same shop that put it in and he said he only pulled out like 1 pound, which sounds like a really low number.
This post has been edited by thatSt204guy: Mar 25, 2015 - 12:15 PM |
Mar 25, 2015 - 12:47 AM |
http://bgbonline.celicatech.com/94_6gmanua...cifications.pdf
24 oz. - about a pound and a half. That switch on the compressor is probably just the switch that signals the clutch to engage. I think if that was your problem the compressor wouldn't even turn on at all. But I'm not sure exactly what to call it and they don't have it listed on Rockauto so I'd guess you'd have to get one from Toyota. -------------------- Bust a Deal; Face the Wheel.
Mar 25, 2015 - 2:44 AM |
http://bgbonline.celicatech.com/94_6gmanua...cifications.pdf 24 oz. - about a pound and a half. That switch on the compressor is probably just the switch that signals the clutch to engage. I think if that was your problem the compressor wouldn't even turn on at all. But I'm not sure exactly what to call it and they don't have it listed on Rockauto so I'd guess you'd have to get one from Toyota. ok so if the guy only pulled out 1 pound, it could be that he didn't put enough in, in the first place? Would being low by 8 pounds cause the AC to just shut off since its so low on pressure? |
Mar 25, 2015 - 12:19 PM |
ok so it isn't a low pressure problem because I had the shop put in the roughly 24oz (or so he says) and it still cuts off and the light still blinks after turning off. Also is there a difference in the AC system from the 5sfe and the 3sge Red Top?
This post has been edited by thatSt204guy: Mar 25, 2015 - 5:38 PM |
Mar 25, 2015 - 9:15 PM |
Is the condenser fan running?
Lo-Fi Version | Time is now: January 10th, 2025 - 9:55 PM |
