2 Pages V  < 1 2
> AC wont stay on Help!, Help!
post Mar 26, 2015 - 12:59 AM
thatSt204guy
Joined Jul 13, '14
From Pasadena, CA
QUOTE (Bitter @ Mar 25, 2015 - 10:15 PM) *
Is the condenser fan running?
How can I tell.
As of right now cold air does come out from the vents but the system shuts off after like 5 secs and then the light for the AC button blinks.
post Mar 26, 2015 - 8:01 PM
Box
Joined Feb 23, '12
From Warrior, AL
Before the car gets up to temp turning the compressor on will kick on one of the radiator fans, can't remember which one though.
2001 Miata LS 5-speed
post Mar 26, 2015 - 8:57 PM
thatSt204guy
Joined Jul 13, '14
From Pasadena, CA
QUOTE (Box @ Mar 26, 2015 - 8:01 PM) *
I went out to check this and when I push the AC button both fans turn on.
post Mar 26, 2015 - 9:30 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
and if the fan doesn't come on the head pressure will get too high and trip the high pressure switch.
If the radiator fan wont come on unplug the wire connector at the very bottom of the radiator to manually bring on the fans and then see if the AC will stay on.
Bust a Deal; Face the Wheel.
post Mar 26, 2015 - 10:54 PM
thatSt204guy
Joined Jul 13, '14
From Pasadena, CA
QUOTE (VavAlephVav @ Mar 26, 2015 - 9:30 PM) *
Just went out and tried this, the AC still turns off after a couple seconds.
post Mar 27, 2015 - 7:44 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
You need a set of gauges to see what system pressures are doing.
post Mar 27, 2015 - 9:42 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
Agreed, you need a set of gages. you could have a blockage in the filter dryer, or in the metering device and you need to be able to read refrigerant pressures to spot that kind of thing.
Does it run for very long at all? If you put your hands on the refrigerant lines running up the fender while it's on Is one of them cold and the other warm?
post Apr 23, 2015 - 5:46 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
I've got the same deal. checked for blockages and nothing. still runs fine with cold air and blinking light. Also sometimes will not cause blinking light. applied 24oz myself to the system The sensor you showed is the speed sensor for the compressor.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Apr 23, 2015 - 6:48 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
hmmm,
I would have to find a factory service manual to find out what the Blinking light means.
You could try looking it up on BGBonline.celicatech.com
post Apr 29, 2015 - 3:26 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
Oddly enough, mine started doing the same thing a couple of days later.
It would work for a few minutes and then it would go off and the light on the AC switch would be blinking.
But a couple of days later it will stay on the whole ride home. The only difference is that it wasn't very warm the other day when it was acting up and now it's kinda hot out.
I haven't had time to fully investigate it but I have noticed, even when it continues to run the compressor is short cycling. Which to me indicates that it's short on refrigerant However I also realized that it may need a bit of compressor oil.
The oil for the compressor is added to the refrigeration system just like the refrigerant, it circulates through the system with the refrigerant.
For a full charge you need a little 8oz can which you can add yourself with buying just a small hose with the valve and fitting on it.
If you don't have enough compressor oil in the system the compressor may chatter or make other noises and could seize up. maybe if it gets jammed and can't turn that is when the light starts blinking?
I've got two more weeks before finals and then I'll have some more time to look into it.
V.'.A.'.V.'.
post May 29, 2015 - 1:11 AM
trdproven
Joined Aug 2, '05
From Guam
A/C Relay
Belt slipping from oil or rain
A/C Clutch bad
High or Low Ref.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
2 Pages V  < 1 2
Lo-Fi Version Time is now: January 10th, 2025 - 11:54 PM
