![]() Enthusiast ![]() ![]() Joined Aug 7, '05 From Columbus OH Currently Offline Reputation: 3 (100%) ![]() |
Can I pull vacuum from the throttle body for my blow off valve? I see two lines going to my charcoal canister, but am not sure if I can use those or not.
The issue I'm having is that the tial valve just isn't opening fast enough, and I'm getting flutter every time I shift. I'm thinking the issue is the length of the run, and the fact that I'm tapping that source in two spots for my boost gauge and boost controller. I purchased the bov spring based on idle vacuum as suggested, but am thinking about getting a lighter spring to compensate for the poor vacuum source. Any suggestions are appreciated. THANKS! ![]() -------------------- ![]() |
You should be using a post Tb source, so anything from the intake manifold is fine. If you don't have it hooked up to a vac source, then that's why it's not working properly.
Thanks for the response. I'm actually using a source right off the intake manifold(the picture shows how my line is run). I was just wondering if there was anything closer to the bov that I could tap into just to make the line shorter, and hopefully in doing so, make the valve more responsive. I'll probably try a lighter spring, and see if that fixes the issue.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
I have a Tial BOV on my Supra, it does the same thing. I think its just the nature of the Tial.
Lo-Fi Version | Time is now: July 4th, 2024 - 1:24 PM |
