Adjusting the valves?, Dont know if i have posted this before... |
Mar 26, 2015 - 9:21 AM |
Enthusiast Joined Nov 25, '13 From Norway Currently Offline Reputation: 0 (0%) |
hey i cant remember if have posted this before but, how hard is it to Adjust the valves?
I rebuild my 7afe and forgot to adjust the vaves after reseating them.. I feel kinda stupid because of that. Any one? |
Mar 26, 2015 - 12:35 PM |
the BGB has details on how to do it. you have to use to special tools (SST) that push down the bucket to make enough room to pop out the shim. its not an easy job to do in the car. personally, I take the cam out to change shims. its much easier.
Mar 26, 2015 - 3:12 PM |
the BGB has details on how to do it. you have to use to special tools (SST) that push down the bucket to make enough room to pop out the shim. its not an easy job to do in the car. personally, I take the cam out to change shims. its much easier. Tnx mate, But taking of the cams is a pain to... Can u buy a set of shims or do u have to do some thing else? |
Apr 22, 2015 - 3:02 PM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
the BGB has details on how to do it. you have to use to special tools (SST) that push down the bucket to make enough room to pop out the shim. its not an easy job to do in the car. personally, I take the cam out to change shims. its much easier. Tnx mate, But taking of the cams is a pain to... Can u buy a set of shims or do u have to do some thing else? You have to measure the gap of each lobe & bucket and refer to a chart in the BGB - There is one for the intake side and one for the exhaust side. That chart will tell you what shim you need to buy to get the spacing back "in spec". Once you do all 16, you can then place your order with the dealer for the shims you need. -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Lo-Fi Version | Time is now: November 26th, 2024 - 8:46 AM |
