> 1jz in a 5th gen, fit ?
post Mar 26, 2015 - 9:53 AM
Dhaopshy
Joined Apr 11, '14
From Wayne nj
i know this is a 6th gen page but i found a 5th ten for really cheap and it has no engine soooo what are the chances a 1j would fit ?
post Mar 26, 2015 - 10:20 AM
Jmk91
Joined Jan 25, '15
From United States
QUOTE (Dhaopshy @ Mar 26, 2015 - 9:53 AM) *
I googled it and everyone said its to long of an engine. 1-3rd gen celica they say its possible. Why not v6 or 3sgte? Tons of people have done it so everything is documented so you'd have no worries and people can trouble shoot any issue for you.
post Mar 26, 2015 - 11:38 AM
mkernz22
Joined May 10, '10
From MA
The 1JZ is an inline 6. With a FWD car, it won't fit transverse since it's way too long. The only way to fit one would be to do a RWD swap and have it sit longitudinal. It would be a complete custom swap that would end up being tens of thousands of dollars to build as well as investing a lot of time if you were to do it yourself.
The 3sgte is a very good engine and will give you some decent power stock. If you find a gen2 3sgte, it would be a bit more simple to swap in than any other generations of the 3s engines because it was made to be in the alltrac. (Wiring is a bit more similar)
Just search about, there are a bunch of threads on engine swaps on here. Also there is a 5th gen Celica page on facebook and they would also be pretty helpful.
This post has been edited by mkernz22: Mar 26, 2015 - 11:39 AM
post Mar 26, 2015 - 12:32 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
since you have no engine, ill assume you have no harness. this is a perfect opportunity to put a V6 in there. 1MZ will do nicely
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 26, 2015 - 7:08 PM
cardshark525
Joined Jan 12, '09
From State College, PA
This is the part where he tells us he's building a custom F1 style race car and will be placing the engine mid-car between the armrest and trunk after gutting the car...... (holds breath)
post Mar 27, 2015 - 12:23 AM
Dhaopshy
Joined Apr 11, '14
From Wayne nj
no no f1 race car i just drive a stock 99 gt and its fun i just wanna build up this 5th gen that i found for $400 and make it a sleeper so to speak i want enough power to surprise people
post Mar 27, 2015 - 2:03 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (Dhaopshy @ Mar 27, 2015 - 1:23 AM) *
So go 1mzfe or 3sgte
post Mar 27, 2015 - 7:40 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (Smaay @ Mar 26, 2015 - 12:32 PM) *
And it won't be a boat anchor like the iron block JZ engines are. Sure you can boost the crap out of them easily but they're still heavy engines.
post Mar 27, 2015 - 3:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
LS Supra=weight reduction=win.
This post has been edited by Box: Mar 27, 2015 - 3:04 PM
2001 Miata LS 5-speed
post Mar 28, 2015 - 2:01 PM
Bitter
Joined Mar 11, '06
Yes, we have a supra sitting in the shop and I tried to talk the owner and my boss into the LS swap and at this point it would have cost less and been done faster.
post Mar 28, 2015 - 6:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
Plus you move the weight inwards and have better balance. I've seen where some people have used an extensively modified 1UZ as well.
Lo-Fi Version Time is now: February 17th, 2025 - 12:46 AM
