> Help just put rebuilt 7AFE in and wont start!!
post Mar 26, 2015 - 4:17 PM
gbloomer
Joined May 19, '14
From Waco TX
Okay, i just finished put my rebuilt 7AFE in my 95 ST made sure the wire harness is all plugged in, in the engine bay as well as inside. Put all the fluids in, hooked up a fully charged battery and tried to start her up. but no such luck. when i turn the key i can hear a click from the ecu area but that is it. The starter doesnt even make a noise. With the key in the on position the door ajar light map lights and headlights work. but the clock, cd player are not lighting up or turning on. I have double checked all the plugs from the wire harness that plug in under the dash and they are all secure. Any help is much appreciated!!
post Mar 26, 2015 - 8:09 PM
Box
Joined Feb 23, '12
From Warrior, AL
Would make sure the starter is properly grounded and connected. I think there's a ground from the head and/or intake to the firewall as well. Also it sounds like the fuel pump relay and ignition switch is working, would check out the starter relay though.
2001 Miata LS 5-speed
post Mar 26, 2015 - 9:08 PM
gbloomer
Joined May 19, '14
From Waco TX
Just found that the wire harness wasnt clipped all the way it to the fuse box next to the battery. thanks though!
Lo-Fi Version Time is now: November 26th, 2024 - 8:50 PM
