Enthusiast ![]() Joined Aug 28, '14 From Okemos, MI Currently Offline Reputation: 0 (0%) ![]() |
has anyone tired to make a gated shifter bezel instead of a boot? I've tried to search for it but have had no luck. maybe i should just measure the shift points and try it.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
If I recall correctly the shifter throw isn't long enough for a gated bezel
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
why is the throw length too short? the shifter follows a set course when you shift. if that course is measured and the correct tolerances added then why wouldn't it work? sure the gates might look a bit short if that may be the case.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) ![]() |
It's not that the gates are short, they overlap. I wanted a gated plastic cover but ended up just having a hole. I still prefer that compared to the leather booth.
ohh well maybe ill see what i can come up with, i just done like how the shift boot rests against the shift knob.
Lo-Fi Version | Time is now: February 20th, 2025 - 2:50 PM |
