> Rattle in the Rear - Squeaky in the front
post Apr 2, 2015 - 3:02 PM
tymish
Joined May 13, '13
From USA
My '95 GT convertible 143,000. An annoying rattle from the back, seems more prominent at slower speeds. It's been going on a few years now. Can't find anything loose in the trunk or spare area.
In the front the suspensions squeaky sometimes, especially when the wheel is turned all the way and it's cold.
New struts and sway bar end links installed.
This post has been edited by tymish: Apr 2, 2015 - 3:16 PM
post Apr 2, 2015 - 3:17 PM
Box
Joined Feb 23, '12
From Warrior, AL
Have the struts and strut mounts been replaced?
2001 Miata LS 5-speed
post Apr 7, 2015 - 9:15 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Do you still have the jack in its holder on the side of the trunk?
post Apr 8, 2015 - 11:11 AM
Jmk91
Joined Jan 25, '15
From United States
Also is your spare tire could somehow managed to become loose.
post Apr 8, 2015 - 4:46 PM
Box
Joined Feb 23, '12
From Warrior, AL
The struts have arrows on them that're supposed to point out, so it could be that.
post Apr 9, 2015 - 12:51 AM
Jmk91
Joined Jan 25, '15
From United States
Only my front struts had an arrow. My rear did not. I also had a rattling noise after a 4 wheel alignment the sound is no longer there.
post Apr 16, 2015 - 11:14 AM
tymish
Joined May 13, '13
From USA
Ordered some rear sway bar bushings to see if that fixes it. Heard it's a common issue and a cheap fix. All struts have been replaced but don't think the mounts were. Rear rattle was there before new struts.
post Apr 16, 2015 - 12:25 PM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
Check the strut mount top nuts in the rear. Mine wouldn't tighten down all the way and was causing a rattling in the rear when I installed new struts and springs so I had to throw a couple washers on underneath to be able to tighten them.
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Apr 16, 2015 - 2:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yep, there's a spacer that's supposed to be there. Would just double check that when doing the sway bushings.
Lo-Fi Version Time is now: February 23rd, 2025 - 9:29 AM
