> spark plug tube removal
post Apr 3, 2015 - 1:24 PM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
does anyone know the best way to remove the spark plug tubes i can't seem to get them out and I dont want to break them.
post Apr 3, 2015 - 1:50 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I believe Ive used either vice grips or a pipe wrench
エキサイティングカーレーシングチーム!
post Apr 3, 2015 - 2:23 PM
doory100
Joined Jun 21, '14
Are they pressed in or do they screw in?
post Apr 3, 2015 - 3:53 PM
doory100
Joined Jun 21, '14
Do they pull up and out or are they screwed in?
post Apr 3, 2015 - 8:07 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
first off, why on earth do you want to take them out. its not common for them to leak.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 3, 2015 - 8:55 PM
doory100
Joined Jun 21, '14
To machine the head and do a port and polish. And Im sure one was leaking. I want everything to be leak free when I put the head back in.
Where are the cam followers located on a 5sfe engine?
This post has been edited by doory100: Apr 3, 2015 - 8:57 PM
post Apr 4, 2015 - 8:35 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Can't you just lock two nuts against each other and use a wrench?
Heating down the tube with a heat gun would also probably help.
This post has been edited by Bitter: Apr 4, 2015 - 8:35 AM
post Apr 4, 2015 - 11:51 AM
doory100
Joined Jun 21, '14
so they screw in or are they pressed in??
post Apr 4, 2015 - 12:32 PM
Bitter
Joined Mar 11, '06
I thought they were threaded in at the bottom?
http://www.toyotanation.com/forum/107-camr...-threads-2.html
This post has been edited by Bitter: Apr 4, 2015 - 12:35 PM
post Apr 5, 2015 - 12:33 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
they are threaded at the bottom just as they are at the top.
sorry I forgot about this thread
エキサイティングカーレーシングチーム!
post Apr 5, 2015 - 2:07 AM
mi645
Joined May 23, '12
From northridge,CA
There is a special tool that u hammer in the tube and it expands inside and then u put a ratchet on it and it loosens up or u can put the 2 30mm nuts together like the earlier person stated and loosen them that way. These do leak from time to time. I just clean them up and put fipg and seal them.
post Apr 5, 2015 - 10:39 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i dont think FIPG seals them good enough. too much heat.
have a machine shop do a pressure test, that will tell you i they are leaking. and you dont need to remove them to do a P&P.
cam followers?
post Apr 6, 2015 - 8:40 AM
doory100
Joined Jun 21, '14
got them out!! they were a pain but they screw out I used the extra 30mm nuts I had together. I don't recommend using your good ones because they were ruined by the end of it. I tapped the ends of the tubes with the nuts in place with a mallet to free them up a bit.
post Apr 6, 2015 - 6:15 PM
mi645
Joined May 23, '12
From northridge,CA
Good job!!
Lo-Fi Version Time is now: February 22nd, 2025 - 3:17 AM
