> e153 Trans into 6gc
post Apr 3, 2015 - 3:44 PM
krzkon
Joined Mar 18, '15
From iowa
Ok. Since my transmission on my 97 Celica ST has started going out, I have decided to go 3sgte.
I will be using E153 Trans from mr2.
The axles are most confusing to me.
I know to use the ST185 outer with MR2 turbo inner.
My question is...
Which joint do I do the splice? the inner of the axles or the outer joint of the axles?
Which axle do I use the actual shaft from?
I have seen the write up on "How To" convert to FWD and looks pretty straight forward.
Every thread I have come across just stated to use mr2 inner and ST185 outer.
Thank you guys in advance.
Lo-Fi Version Time is now: January 12th, 2026 - 7:15 PM
