Airbag light and a light during hard breaking |
Apr 12, 2015 - 10:59 AM |
Enthusiast Joined Jul 6, '12 From NORWAY Currently Offline Reputation: 0 (0%) |
Hello
When i start my Celica and the engine is cold, there is no lights at all. But when ive driven for around 4km's the airbag light comes on. When i shut down the car and start it back up again, the light works as it normally do (lights up and goes off again when you start up the car) and after 2sec to 2mins it comes back. Anyone has an idea of what might be wrong? The car has a 7gc steering wheel in it. The other thing is when i do hard breaking, the warning light for brakes light up, and when i get of the pedal, it disappears. The pedal feels fine and the ABS works as it should. Might be a little low on brakefluid? |
Apr 12, 2015 - 1:14 PM |
Enthusiast Joined Jan 25, '15 From United States Currently Offline Reputation: 4 (100%) |
Not sure about air bag. On the brakes just check your fluid to see if that's the issue. Takes 30 seconds.
Apr 22, 2015 - 3:46 PM |
Enthusiast Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) |
Sounds like your clock ring is going bad for the airbag light to only come on like that, at least thats my first thought on it.
-------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
Apr 22, 2015 - 8:28 PM |
It would be best to read the code for the airbag and go from there, there's a few parts in the system and blindly changing parts can be costly.
Apr 23, 2015 - 10:07 AM |
As Bitter mentioned you can read the code that is triggering the light to come on.
Follow these links to the info you need to do so: http://www.airbagsolutions.com/docs/codes/toy.pdf http://www.diycardoctor.com/Downloads/SRS%...bag%20Codes.txt -------------------- 1997 ST:Limitedly Green
Apr 25, 2015 - 3:37 AM |
Allright, ill fix it when i get the time. Thanks alot!
But i think it is wierd, when i start the car in the morning i get half way to work before it starts to light up (15min into the 30min drive) |
Lo-Fi Version | Time is now: January 9th, 2025 - 1:23 AM |
