Enthusiast ![]() Joined Sep 9, '08 From Jamaica Currently Offline Reputation: 1 (100%) ![]() |
ok, bought these camshafts, installed em and they work great...used some adjustable camgears and so they are set to 0 degrees (stock cam timing)...any tips for what advancement or retardation on either shaft to generate more power??
CATCAMS 7107175 prt# Duration 258/242 degree Max Lift 10/8.85 mm lift at TDC 1.45/0.5 mm im thinking small advancement (~2 deg) on the intake and medium retardation (~5 deg) on exhaust...then work from there...anyone with better starting point? or tips... |
Lo-Fi Version | Time is now: February 18th, 2025 - 10:15 AM |
