> A140E transmission mounts
post May 1, 2015 - 7:36 PM
Javve
Joined Mar 13, '15
From Washington State
I have been looking for a replacement transmission. I noticed on cars that are listed as compatible that the mounts are in different locations and seem to be bolted differently. Have not removed one to check and see exactly how it is done as it would be hours at a junk yard. On the ones I am speaking of, the transmission mount is on the sub-frame which goes all the way across to the front. If they can be removed and I use mine, it would make finding one a ton easier.
Are the transmissions the same with just different mounts that can be swapped?
95 GT Convertible 2.2L 5S-FE Auto
Purple-Blue
Given to me with bad tranny
Going to bring car back to life.
160K miles
post May 1, 2015 - 8:44 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
same trans probably came on Camry with 5S-FE. but they will not be the same mounts for a celica. you need celica auto mounts only.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 1, 2015 - 10:11 PM
Javve
Joined Mar 13, '15
QUOTE (Smaay @ May 1, 2015 - 9:44 PM) *
Thanks for the info. That means I'm limited to Celica for donor.
Purple-Blue
160K miles
post May 29, 2015 - 1:13 AM
trdproven
Joined Aug 2, '05
From Guam
On our celicas, for example if you are swapping from auto to manual, i remember only the manual mount you needed and you can still use all the auto mounts (pass, rear, front)
Of course though the manual mounts appear and is stronger in the rubber design due to vibrations it has to handle.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: January 11th, 2025 - 2:55 AM
