AN 10 fitting for turbo return |
May 5, 2015 - 7:12 AM |
Enthusiast Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) |
Hey guys.
I am in the process of turbocharging my UK Spec 3SGE. I have a spare sump pan (see pic) that I would like to drill for AN10 fitting. I have never used these fittings before. My question is can I do this without welding? Also is it worth tapping the pan for an oil temperature sensor? I'd like to see pics of your drilled pans please. Many thanks, Jason. |
May 5, 2015 - 11:38 AM |
Enthusiast Joined Dec 9, '05 From Germany Currently Offline Reputation: 0 (0%) |
I wouldn't put the oil return in the lower oil pan, the return should be above the oil level so it can flow freely. You should try to get a fitting in the upper aluminum oil pan.
May 26, 2015 - 11:49 PM |
yes you dont want the return that low. you want to put it in the sub pan like the 3rd Gen 3S-GTE
Lo-Fi Version | Time is now: December 4th, 2024 - 6:39 PM |
