> headlight problem
post Feb 16, 2004 - 12:40 AM
mjmsoccer
Joined Aug 13, '03
From Greencastle, PA
Hey guys I was wondering if someone could help me out here. I rewired my foglights today, (aftermarket) and wired them into the headlights. I disconnected the low beams and brought the positive from the foglights up and matched it to the headlights. I turned my lights on and everything was working fine (low beams and fogs). Then I turned the high beams on and the entire passenger side went lights went out, but the driver side was fine. confused.gif Then after turning the highs off my driver side low was fine but the passenger side high and low were both still on. Could this possibly be because there is not enough power to run the fogs along with everything else? Thanks
post Feb 16, 2004 - 12:41 AM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
Should have run them to the running lights in your turnsignals or the fender lights.
Jared Harwell
post Feb 16, 2004 - 12:48 AM
mjmsoccer
Joined Aug 13, '03
thanks phat. I'll check that in the morning and see what happens.
post Feb 16, 2004 - 5:23 AM
macavely
Joined Nov 4, '02
check i'm not sure about the celi cause i haven't done it yet.. but most toyotas.. have the extra outlet from the fuse box were you hook up the foglights from... thats were you should hook your fog lights from...
post Feb 16, 2004 - 9:00 AM
mjmsoccer
Joined Aug 13, '03
thanks macavely. i never thought of doing that. I had them hooked up with my own switch til the switch broke I'll look at it today after class and let you guys know.
post Feb 16, 2004 - 3:27 PM
snadman
From Minnesota, USA
Yehp, that should solve your problem. Excellent diagnosis Dr. Macavely. biggrin.gif
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Feb 16, 2004 - 3:29 PM
mjmsoccer
Joined Aug 13, '03
the foglight fuse is located in your dash correct? Where is the output of that fuse located?
post Feb 16, 2004 - 8:53 PM
mjmsoccer
Joined Aug 13, '03
alright guys thanks for all your help, i ended up wiring them into the side markers and everything is alright. I had a blown fuse which was screwing up the headlights
post Feb 16, 2004 - 11:56 PM
macavely
Joined Nov 4, '02
QUOTE (mjmsoccer @ Feb 16, 2004 - 4:29 PM)
there should be 2 fuse for the foglights one under the dash and one under the hood..
Lo-Fi Version Time is now: December 4th, 2024 - 5:17 AM
