> "Frankenstein motors", Putting together a motor from the parts of a bunch of diff motors
post May 14, 2015 - 3:07 PM
lokishadow87
Joined Apr 19, '15
From 5856547
So I was talking to one of my buddies at my 1994 Toyota celica st and mentioned something about Frankenstein my motor with the gt version of my car.Is this possible and if so what would be the best set up
post May 14, 2015 - 3:53 PM
cardshark525
Joined Jan 12, '09
From State College, PA
http://www.6gc.net/forums/index.php?showtopic=73956
post May 16, 2015 - 9:56 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
there is nothing interchangeable between the 7A-FE and 5S-FE. they are totally different engines
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 16, 2015 - 6:45 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yup. Now a 4A and a 7A, or a 3S and a 5S is another story.
2001 Miata LS 5-speed
post May 16, 2015 - 7:42 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
And a huge investment for questionable gains.
post May 17, 2015 - 11:29 AM
lokishadow87
Joined Apr 19, '15
From 5856547
Well I have the 7a. Are there any parts from the 4a that are better? Or what I was thinking at first are there any other model car that comes with the same motor but better parts within the them then I have in my stock one
post May 17, 2015 - 7:35 PM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
the 5sfe GT motor is better and stronger than the 7afe motor. If you can get cams off a 7afe motor from the junk yard and send them out to get reground to a different profile you will get better gains that way. I think the corolla has the 7afe motor as opposed to the Camry with the 5sfe motor
post May 17, 2015 - 8:20 PM
Bitter
Joined Mar 11, '06
They're both economy engines. In my opinion the 7A is the more advanced of the two, it makes more power per liter than the 5S and revs more readily as well as having a great torque profile. The problem with both engines is breathing and revving, they don't do either very well which limits their power. The early 7A with adjustable timing takes nicely to some simple bolt ons and is shockingly full of pep.
post May 17, 2015 - 8:21 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
cams are not going to help the 7A. you might gain 5 HP.. not worth the cost of getting cams done.
the only thing you can do is boost the engine or do a swap.
post May 17, 2015 - 10:37 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Bitter @ May 17, 2015 - 8:20 PM) *
Don't forget decently more efficient. The 7A was peppy for what it was though, certainly not the worst economy engine out there from the time.
Really you're better off swapping to a V6, BEAMS, or 3S-GTE.
Lo-Fi Version Time is now: February 13th, 2025 - 2:49 PM
