![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '05 From Indianapolis Currently Offline Reputation: 0 (0%) ![]() |
in and attempt to get a rusty, stuck, and almost stripped bottom bolt out of the piping to replace my thermostat, I unscrewed a piece on top of what I think was the A/C unit. Pressure was released. What did I just do?
Released the pressure from your AC system.
and hopefully you didn't breath the refrigerant in cause you could die....well get kind of sick.
How do I remedy this issue?
By going to a shop and getting your ac system charged.
If you let everything out you'll have to get an A/C shop to pull a vacuum and refill it, if you were able to stop it in time you could top it off yourself.
Lo-Fi Version | Time is now: February 13th, 2025 - 9:30 AM |
