> Idle Up Valve P/N? And other stuff
post May 19, 2015 - 6:02 PM
pandito
Joined Apr 15, '15
From California
Does anyone know the part number for the A/C Idle Up Valve? My 98 GT vert idles rough-er than normal when the AC is on and I think I've localized the problem to either a failing or an altogether bad A/C Idle Up Valve.
Now, previously, she would do this weird slight drop in RPM when coming to a stop so I planned to clean the throttle body as well as the IACV. Problem was that I couldn't disconnect the water lines from the TB (which is connected to the IACV) so I instead just cleaned the TB as best as I could with the air and water hoses still attached. It's idling better, but doesn't solve the rough-er idle when under AC load.
Going a little further, how do you remove the water and air hoses from the IACV / TB?
And, lastly, are there any part numbers for those specific hoses that go from the TB to the EGR-VM as well as the throttle opener? Or can I use any hose that fits those openings?
post May 20, 2015 - 7:16 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
water lines have a clamp on them. pinch the clamp, move out of the way and pull water lines off. simple
This post has been edited by Smaay: May 20, 2015 - 7:16 PM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 20, 2015 - 9:39 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
May need to twist the lines with pliers if they're seized to the nipples and won't pull free.
Lo-Fi Version Time is now: February 19th, 2025 - 1:34 AM
