> urgent!, car wont go past 4k and violently jerks in 4th or 5th
post May 23, 2015 - 12:36 AM
frankfng
Joined Apr 27, '15
From United States
Alright guys. I got a 97 vert with a 5sfe. I just got it and am now having issues. One of the vacuum hoses fell off so i bought some clamps boom fixed right? Guess not because on the freeway my car will jerk violently if i dont either depress the clutch or slam on the accelerator. Car is very sluggish and will not go past 4k. And usually jerks when i hit about 70. The only way i found to avoid the sluggishness is revving it high when taking off and slowly letting off the clutch wearing it down very very fast im sure. My question is what in the world is going on with my car? Both the sluggishness and the jerking at higher speeds. There is also a slight whine or whistle under the hood from when the hose fell off that didnt fully go away. I really need the advice as this is my first celica and my first own car. Anything helps! Thanks.
-frank
post May 24, 2015 - 12:35 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
there are too many possibilities for whats wrong. its a 97 so do you have a CEL on? get the codes read. i would take the car to a mechanic to be diagnosed. then post here whats wrong.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 24, 2015 - 10:19 PM
rdyzz
Joined Dec 27, '11
From minnesota
I would start by checking for vacuum leaks and ignition related items.
post May 25, 2015 - 1:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'd go over all the basics first; check fuel pressure, check timing, check for vacuum leaks, check condition of spark plugs and air filter, and check compression. Any of those things being wrong can cause your problem. Another thing to look at would be the MAP sensor. Though many of those things should throw a CEL on an OBD-II car, make sure the light is coming on when you turn the key to the ON position.
2001 Miata LS 5-speed
post May 25, 2015 - 5:43 PM
igpx12
Joined Jan 30, '14
From Cortland NY
So you can go past 4K while in neutral but not while in gear? And while idling the engine doesn't shake or idle rough, just has a whine to it? If this is the case, definitely recheck your vacuum lines, check where the vacuum line went to and see if there is a clog in the system, if so run some seafoam in through a vacuum line. Maybe check your map sensor too by unplugging it, once with the vacuum line and once with the connector and see if there is a difference. Also did these issues happen before your vacuum line issue that you had fixed?
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
Lo-Fi Version Time is now: November 30th, 2024 - 1:46 AM
