> 3SGE Idle Issues on AC
post May 25, 2015 - 9:17 AM
Kiolofunk
Joined Jan 2, '15
From Philippines
As the title suggests, idle on my motor is really problematic lately (3SGE 3rd Gen installed on a 7th gen corolla) - well not all the time. Basically, what happens is when I'm stuck on traffic (I'm in the Philippines btw) and it stretches for 10 kms stop and go, max speeds at about 10 km/h on a very hot sunny day. Idle starts to bog down to 500 rpms +/- 50 and sometimes even 200 rpms. So i turn off the AC and idle normalizes to about 1000 rpms then it starts to fluctuate 800 - 1000 rpms every 5 seconds or so then idle goes back to normal after 10 minutes. Turn the AC on and run the usual traffic for another 30 minutes and on with the same problem.
What i've done so far:
Spark plugs
Ignition leads
Rotor cap
Also, i've replaced the following as it was due however, not sure if it adds up:
Coolant Temperature Sensor
Thermostat
Fuel Filter
Last weekend cleaned my IACV and took the TB apart and IACV apart. Noticed that the valve or the gate that opens/closes doesn't go smoothly and it seems that it does not fully close, there's a gap on gate about 1-2mm. Gave it a good clean and put everything back on, reset the ECU and drove about 50 kms and it was fine at first as there wasn't any traffic cause it was a weekend so gave up on it and tested it earlier when it was hot and was on my way to work and it started again!
Really need advice. By the way, i don't have any CEL (literally) - the person who installed my engine decided that CEL was just a headache so it's much better not to have it. Anyway it's a long story and I haven't seen him since and i'm dying to wire him up on my loom. It was running perfect before so i didn't bother much though i was meaning to get it sorted. I know, my bad.
Basically, it only happens on midday and I've never had this problem at night. Not sure if it's the weather here however it was working well before so might as well.
PS: Will upload pics of the IACV gate when i get the chance to open it again this weekend
Thanks 6GC!
post May 25, 2015 - 12:35 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
the iscv aint controll the A/C idle up
if it is gen.3 (ST205) ,there is a line going from the oem intercooler (single connection on the backside of the IC) to a valve and then to the intake manifold, this is where i see the problem
greetz
KEEP COOL UNDER PRESSURE
post May 26, 2015 - 6:55 PM
Kiolofunk
Joined Jan 2, '15
From Philippines
Thanks for the input however the car is a corolla with a transplanted ST202 3SGE 3rd Gen motor.
I forgot to mention that I've replaced the AC Idle Up with several working ones to no avail.
I'm not really good at troubleshooting this engine yet as I've only owned this motor for 3 months and my previous motor was a 2E carburetor engine.
Reason I thought that the problem is with the IACV is because when I start the motor, the IACV makes a really loud hissing sound like it's opening and closing on its own until the engine fully warms up. Will upload a video of this later when I get the chance.
So basically, I have an issue with the IACV and as well as the AC connection. I just need someone to point me to the things I should focus on.
Any help would be greatly appreciated. Thanks!
Lo-Fi Version Time is now: November 26th, 2024 - 6:33 PM
