> Fuse blown? What to check??
post May 27, 2015 - 8:14 AM
Nphubert93
Joined Oct 30, '14
From PA, USA
When I was putting my aftermarket head unit in, I accidentally touched the constant power to the housing of the head unit. I saw a spark and now I have no power to te constant wire. Checked all fuses under the kick panel on the drivers side, none are blown. Any suggestions? 94 2.2
post May 27, 2015 - 10:24 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
the fuse box in the engine bay has a fuse for the radio I believe
エキサイティングカーレーシングチーム!
post May 27, 2015 - 12:35 PM
qatar11
From Lake Orion, MI
QUOTE (Tigawoods @ May 27, 2015 - 11:24 AM) *
^ +1
Also - google around for a Celica EWD (electrical wiring diagram) Then you can follow the path of the wire.... more often than not - accessory power wires go through more than one fuse. Depending of the fuse type you might not pop the one you would expect (lower current).
This post has been edited by qatar11: May 27, 2015 - 12:35 PM
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 27, 2015 - 4:26 PM
Jmk91
Joined Jan 25, '15
From United States
Should be a red 10a fuse. Always disconnect battery when working with something electrical.. Try connecting red/yellow wires together to see if it powers.on. if it does... Than fuse isn't blown. Some cars are stupid with CD players I had to connect 2 red to one yellow and it works fine. I have one yellow not connected and I have my memory for head unit still. Yellows constant power and reds 12v.
Lo-Fi Version Time is now: November 29th, 2024 - 10:59 PM
