> My celica fail emission please help lol 😭
post May 30, 2015 - 6:50 PM
Oreo20
Joined Jan 27, '14
From Houston
I'm a sensitive person so I'll be crying durning I type this lol
Car failed emission
Results:
HC(%) standard 147 current 124. PASS
C0(%) standard 0.82. current .55. PASS
NOx(ppm) high speed standard 107 . Current 1301
And low speed standard 1186 current 1448
I failed by like 300 points lol
What can I do to fix it
Car idles fine at 800 rpm I've already done a full tune up
Please help find the cure /:
What is NOx ppm anyways
post May 31, 2015 - 8:54 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
NOx is http://en.wikipedia.org/wiki/NOx
And it's bad.
The EGR system is designed to lower combustion temperature to reduce NOx formation, if it's not working properly you'll have high NOx numbers. The catalytic converter also converts NOx but since your other numbers look good I'm not sure it's gone bad. Timing (spark timing or mechanical timing) being off can affect NOx as well.
post May 31, 2015 - 8:57 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
time for a new CAT.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: November 30th, 2024 - 4:09 AM
