> Power Steering Fluid
post Jun 9, 2015 - 9:04 PM
kloudkicka
Joined May 8, '04
From Winnipeg
Hey guys, so i have a swapped 3rd gen 3sgte and i want to top off my power steering fluid, i looked it up to see what kind of fluid is needed and it said dexron ii, but apparently they dont make it anymore, so my question is, what do u guys use? And is it the same for all 6th gen motors? Thanks
post Jun 9, 2015 - 9:24 PM
Box
Joined Feb 23, '12
From Warrior, AL
Dexron-III took over for Dexron-II and is available at Wal-Mart.
Just noticed you're in Canada, so whatever grocery store chain with an automotive section you guys have should have it to.
This post has been edited by Box: Jun 9, 2015 - 9:24 PM
2001 Miata LS 5-speed
post Jun 9, 2015 - 9:25 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Ive heard people use Automatic Trans Fluid. Im not sure if that is whats supposed to be used but I used Lucas Oil Power Steering Fluid
エキサイティングカーレーシングチーム!
post Jun 9, 2015 - 9:35 PM
Box
Joined Feb 23, '12
From Warrior, AL
Dexron is ATF. Some power steering systems call for ATF, some for DOT 3, some are either/or. Power steering fluid is more like ATF but without all of the detergents.
Then you had Ford which specified Mercon which is more or less their version of Dexron.
Point being it's important to use what's called for as DOT 3 isn't compressible, isn't full of detergents, and is hygroscopic so using one in a system designed for another can make a real mess of things.
post Jun 9, 2015 - 10:20 PM
kloudkicka
Joined May 8, '04
From Winnipeg
Okay so dexron iii should work? I just dont wanna mess anything up putting the wrong fluid, not sure what was in there before but would it be bad to mix fluids? Cuz all i really wanted to do was top it off cuz it was looking a little low
post Jun 9, 2015 - 10:30 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Yup, Dexron is backwards compatible.
post Jun 9, 2015 - 10:36 PM
kloudkicka
Joined May 8, '04
From Winnipeg
Okay cool, thanks for the all the help guys, much appreciated, i did look up the fluid and it did say that dexron iii was the replacement fluid, but then the website i was on got all complicated naming other brands and types so i thought asking the 6gc community would be easier, so i appreciate getting the answer
post Jun 9, 2015 - 10:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
Dexron-III replaced Dexron-II ages ago. Just make sure the fluid says it's Dexron-III/Mercon compatible and you'll be good to go.
post Jun 9, 2015 - 10:46 PM
kloudkicka
Joined May 8, '04
From Winnipeg
QUOTE (Box @ Jun 10, 2015 - 3:44 AM) *
Awesome, will do, thaaanks box
Lo-Fi Version Time is now: February 18th, 2025 - 5:47 AM
