Enthusiast Joined Sep 16, '14 From Norway Currently Offline Reputation: 0 (0%) ![]() |
Both my doors are rusted all up and i Need to get a couple of new ones.
I was lucky enough to find one pair really cheap but i need to act fast. I have the normal 1.8l ST coupe, I am not sure if the doors is from 6th or 5th, but if it is from 5th will it fit? Here is the doors im looking at ![]() |
That door definitely is not from a 6th gen and will not fit, unfortunately.
Are you 100% sure?
I saw on another forum that a guy told he fitted a 6 gen door on a 5th gen easy.. wouldnt it work the oter way around? Last post on this one? http://www.toyotacelicas.com/forums/94-fif...forumsite/21173 |
Enthusiast ![]() ![]() Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) ![]() |
Are you 100% sure? I saw on another forum that a guy told he fitted a 6 gen door on a 5th gen easy.. wouldnt it work the oter way around? Last post on this one? http://www.toyotacelicas.com/forums/94-fif...forumsite/21173 Those are 5th gen doors, the front part of the door will have a minimum 1 inch gap all the way down, the angle of the doors is off by about 5-10 degrees, and the mirror location doesnt line up either. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:44 AM |
