> 3SGTE's transmission from AWD to FWD
post Jun 15, 2015 - 2:02 PM
empite
Joined Nov 14, '14
From greece
i bought Front clip swap days ago St205 .planning to convert the ST205's gearbox to FWD from AWD , is there anybody who did this or knows how ?
post Jun 15, 2015 - 3:19 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
It should be on the stickies.
God made man....
Everything else...
Made in China
post Jun 16, 2015 - 10:13 AM
rave2n
Joined May 29, '09
From Gainesville, FL
pretty sure it never works out well with the e154f. Something always breaks premature from the conversion.
post Jun 16, 2015 - 1:05 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
its not easy and its very expensive. you have to first separate the transfer case. then open the trans and remove the differential. (AWD has a long shaft in it for the transfer case) then you need to buy either an open differential from a camry/solara, or LSD . you need the new cover plate and axle seal.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 17, 2015 - 3:03 PM
empite
Joined Nov 14, '14
From greece
i'll try it and if it will work i will post it step by step:D . but for sure that is gonna be full "lock" the GT4 trans is 50-50 right ? the car probably will not turn hahahah
post Jun 17, 2015 - 8:41 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (empite @ Jun 17, 2015 - 4:03 PM) *
It only won't turn right if you weld the diff.
Lo-Fi Version Time is now: November 25th, 2024 - 1:38 PM
