> ST205 radiator part number???, common radiator with another toyota?
post Jun 19, 2015 - 8:03 PM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
The radiator on my ST205 is leaking. I tried pouring in the stop leak fluids with aluminum bits to seal it but it didn't work.
Does anyone know the OEM part number for a new radiator?
Does the ST205 have the same radiator as a more common toyota that I can find at a junk/parts yard? If so what model and year?
Any help would be much appreciated.
post Jun 20, 2015 - 12:52 AM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
Sure thing! If you go to autozone and order one for a 94-99 GT celica it's the same size, core thickness and outlet locations as the 205. Had the same issue with my swapped ST not long ago. Hope this helps!
Lift Addict!! ^_^
post Jun 20, 2015 - 1:18 AM
Box
Joined Feb 23, '12
From Warrior, AL
Yup, radiator for the ST204 be the same. I want to say Koyo makes an o.e. replacement, I'd go with them if I were buying new.
2001 Miata LS 5-speed
post Jun 20, 2015 - 2:35 AM
1994Celica
Joined Aug 5, '09
From West Texas, USA
I'd say buy an aluminum one will you're at it. More expensive but worth it.
JDM Part King
post Jun 21, 2015 - 6:19 PM
nammer
Joined Aug 22, '07
QUOTE (Ryouxrs @ Jun 19, 2015 - 10:52 PM) *
QUOTE (Box @ Jun 19, 2015 - 11:18 PM) *
QUOTE (1994Celica @ Jun 20, 2015 - 12:35 AM) *
Thats awesome. Thanks a lot! I will look into getting one from an st204. My clutch is slipping too so I have to address that also. One thing after another...
post Jun 21, 2015 - 9:35 PM
Box
Joined Feb 23, '12
From Warrior, AL
If your car is mostly stock I'd just go with the Koyo o.e. replacement, the original plastic tanked radiator made it this long so the next should outlive the car. Especially being you need a clutch soon the money saved between an o.e. replacement and a good aftermarket radiator would cover a clutch kit.
post Jun 22, 2015 - 1:27 AM
nammer
Joined Aug 22, '07
QUOTE (Box @ Jun 21, 2015 - 7:35 PM) *
Good call. That's what I'm going to do. From what I've read, ST205 clutch jobs can be long, like 15-20hrs at the shop because the gearbox needs to be removed? Might have to pass the car onto someone else and move on if that's the case... frown.gif
post Jun 22, 2015 - 2:08 AM
Box
Joined Feb 23, '12
From Warrior, AL
Every car the transmission has to be dropped to change the clutch, AWD is just a real pain since it's like doing a clutch job for a FWD and RWD car all in one. If you mechanically savvy I'd look into doing it myself, that or maybe you have friends or family that could help you out.
post Jun 22, 2015 - 11:57 AM
nammer
Joined Aug 22, '07
QUOTE (Box @ Jun 22, 2015 - 12:08 AM) *
I'm somewhat Savy but not enough for a clutch job. Can't afford to have the car down for a few days if things go sideways haha. Thanks!
post Jun 24, 2015 - 4:33 PM
texasnick
Joined Feb 23, '10
From Vancouver, BC
QUOTE (nammer @ Jun 22, 2015 - 11:57 AM) *
You'll actually have to drop the whole engine/tranny assembly to change the clutch. I think there is a way to do it without dropping the trans, but it isn't easy. gt40c has a detailed explanation.
I got quoted 24 hours to do a clutch job by vex in red deer, ab.
Nick
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 7th, 2025 - 10:53 PM
