should my turbo sound like this?, constant whine from the turbo from 5-15 psi |
Jun 30, 2015 - 12:35 AM |
Enthusiast Joined Dec 9, '14 From Juneau, Alaska Currently Offline Reputation: 3 (100%) |
I get a constant whine from the turbo that doesn't change pitch regardless of rpm or boost pressure. I think it may be a leak but I'm not sure.
is this sound normal?? view the video to hear it strange turbo whistle Thanks Anton |
Jun 30, 2015 - 8:25 AM |
Cant really tell in the video. Ill watch it again when I get home.
Jul 2, 2015 - 11:20 AM |
Enthusiast Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
Sounds like a bit of an exhaust leak. My truck was leaking just after the turbo where it bolts to the downpipe and it was whistling like that. Of course it was a diesel so was easy to see black smoke pouring out of the hole when i revved it up. Yours might be a little more difficult to pinpoint but try squirting soapy water on some of the joints before it heats up and you'll see it bubbling if you are leaking
-------------------- ST205 Crew represent
Challenge Accepted |
Jul 3, 2015 - 12:12 AM |
thanks schmooot! I'll give it a try. I really need to pressure test the whole thing. I'm sure something is probably leaking.
Jul 15, 2015 - 11:39 PM |
I found my problem. I had a boost leak on one of my boost fittings, my brake vacuum line, or my power steering vacuum idle up switch. I repaired these issues and tightened my boost hose fittings and the noise went away. I'm very glad it wasn't my turbo giving out.
Lo-Fi Version | Time is now: October 27th, 2024 - 3:09 AM |
