> Name that part!, Needing help to identify a part.
post Jun 30, 2015 - 12:20 PM
rapid36
Joined Feb 5, '13
I am curious what this part is called? I believe its the PCV valve and im in need of a new one, and when I look around on ebay i dont find any or the part looks completely wrong. any idea on what it is? Am i right?
FYI this isnt a picture of my engine bay.
post Jun 30, 2015 - 12:28 PM
Box
Joined Feb 23, '12
From Warrior, AL
Fairly sure that's the PCV valve, and there's supposed to be a port on the intake manifold up under the fuel rail if I recall correctly.
2001 Miata LS 5-speed
post Jun 30, 2015 - 12:31 PM
rapid36
Joined Feb 5, '13
QUOTE (Box @ Jun 30, 2015 - 12:28 PM) *
Kk thank you, I just wanted to verify this :-). Although Now i need to find out how to get a new one lol. ebay i guess doesnt have the correct pcv that im looking for. which is pretty surprising.
post Jun 30, 2015 - 1:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just hop onto RockAuto and Amazon, then can cross-reference parts numbers if you feel like it.
post Jun 30, 2015 - 2:56 PM
rapid36
Joined Feb 5, '13
QUOTE (Box @ Jun 30, 2015 - 1:58 PM) *
rock auto? hmm interesting. I never heard of that before. Thank you! I will look into it :-)
post Jun 30, 2015 - 2:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
$3.70 shipped before 5% discount off RockAuto for a Fram valve, or a little more or little less depending on whicher brand you prefer.
Just Google "RockAuto Discount Code" and RetailMeNot will have the code which you paste into the "how'd you hear about us" section of the checkout.
post Jun 30, 2015 - 3:36 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
I just replaced mine On my 7afe, It was 2.99 at oreilly and I bought new hose too and a grommet. You'll need a grommet... Total was under $7
post Jun 30, 2015 - 3:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yep, grommet. $5.55 shipped for Fram PCV valve and Beck/Arnley grommet.
Don't have to waste fuel or deal with people, it's a win win win. tongue.gif
post Jun 30, 2015 - 6:36 PM
rapid36
Joined Feb 5, '13
QUOTE (Box @ Jun 30, 2015 - 2:58 PM) *
Dude that site is awesome! Thank you so much for showing me that!!!! As always your a pleasure to talk to box! And I do have another question, how do you remove this valve? Any ideas? I watched some YouTube videos for some other types of PCV valves and they just pull it out of there. Im kinda scared to just yank mine out of there if its suppose to come out a different way. Can someone verify this for me?
post Jun 30, 2015 - 6:42 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
Bust a Deal; Face the Wheel.
post Jun 30, 2015 - 6:47 PM
rapid36
Joined Feb 5, '13
QUOTE (VavAlephVav @ Jun 30, 2015 - 6:42 PM) *
https://www.youtube.com/watch?v=awGrZGiqs5Y
I think this pretty much sums it up for me. I know its for the 5sfe but Im sure its very similar for the 7afe.
post Jun 30, 2015 - 7:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
It just pops out while smashing your hand into the fuel rail and intake, pretty straightforward stuff. I think I might've used a flat blade screwdriver to pop it out since I value my hands.
post Jun 30, 2015 - 8:12 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
Just use a pair of needle nose pliers and pull it out, the grommet will be in there still. Then you can get a razor blade and cut it up, have a vacuum ready to suck up the parts that fall into the hole. Once you cut out 1/4 of it, you can pull it out with the needle nose pliers.
post Jun 30, 2015 - 8:21 PM
Box
Joined Feb 23, '12
From Warrior, AL
No need to be cutting things up, put the the flat blade behind and under the lip and work it down while applying upwards force.
post Jul 2, 2015 - 7:46 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Take the valve cover off so you don't drop in any rubber parts that crumble off.
post Jul 2, 2015 - 3:47 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (Box @ Jun 30, 2015 - 9:21 PM) *
Lol the grommet crumbled when i tried it thats why i just cut out what i could and pulled it out tongue.gif
post Jul 2, 2015 - 4:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
Fair enough. Mine was still pliable and had been replaced at one point, but I already had a new grommet so it was going in.
post Jul 3, 2015 - 12:51 PM
rapid36
Joined Feb 5, '13
Thanks guys! All very useful information. I will asses the groumet before removal, if its pliable then i will not remove the valve cover, if its not pliable anymore then i will remove my valve cover to remove it.
post Jul 3, 2015 - 2:03 PM
Box
Joined Feb 23, '12
From Warrior, AL
If you do pull the cover remember to grab a new gasket, and since you're already there I'd replace the spark plug tube seals while I was at it.
post Jul 6, 2015 - 1:36 PM
rapid36
Joined Feb 5, '13
QUOTE (Box @ Jul 3, 2015 - 3:03 PM) *
Ah good point! I ordered the parts I needed but I havent ordered a valve gasket and the spark plug tube gaskets, gonna wait till I start the removal process to see what I need to do. Hopefully its an easy job :-P.
Lo-Fi Version Time is now: November 24th, 2024 - 5:41 PM
