4agze ecu for 7afte? |
Jun 30, 2015 - 3:16 PM |
Enthusiast Joined Sep 27, '14 From wyoming Currently Offline Reputation: 0 (0%) |
possibly a stupid question and if it was feasible it probably but what about using a 4agze supercharged mr2 ecu and wire harnesses as a solution for engine control on a low boost 7afte
-------------------- i have a passion for engines and to me not possible just means i need to find a way to do it better.
anything will fit in anything given enough time tools money and knowhow never limit yourself on what you can do to your car. |
Jun 30, 2015 - 8:08 PM |
Enthusiast Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) |
possibly a stupid question and if it was feasible it probably but what about using a 4agze supercharged mr2 ecu and wire harnesses as a solution for engine control on a low boost 7afte If you swap the head to a 4agze head then you can use the ecu, but it won't work with a 7afe head. Doing the head swap would get you a 7agte though if you turbo it, but using the stock ecu would be silly for the amount of work you'll put in. A stand alone would be much safer/better. |
Lo-Fi Version | Time is now: December 2nd, 2024 - 1:58 AM |
