Enthusiast ![]() Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) ![]() |
Ok sO I changed from my regular Pennzoil high mileage oil to castrol synthetic blend but when I went to refill
I put 4 quarts like usual and didn't even touch the dip stick so I decided to fill the whole 5 quarts and guess what it filled below the top why is that ???? |
That's impossible. Either you're leaking it back out somewhere as it's pouring in, you're reading the stick wrong, or you're pulling the wrong stick. Did you wait for the oil to all settle back into the pan after running the engine? Did you check it with the engine running?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
Did you remember to put the drain plug back in?
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Nor the car is leaking and I turned the car on to let the oil run to the filter its just weird
Lo-Fi Version | Time is now: February 17th, 2025 - 6:52 PM |
