> Have DTC 12 on 1994 ST (1.8L 7A-FE engine) Need help
post Jul 21, 2015 - 10:19 AM
jcrog
Joined Mar 20, '06
My check engine light came on about 2 weeks ago. The error code is 12. It was running fine until yesterday. Now it is stuttering at lower RPMs. Any ideas on the problem?
Let me know if you need more info.
Thanks,
jcrog
post Jul 21, 2015 - 4:11 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
check the wiring between the distributor and the ECU
distributor just died
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 21, 2015 - 5:41 PM
jcrog
Joined Mar 20, '06
How do I check the wiring? On the way home the idle was rough and low RPMs.(around 700)
QUOTE (Smaay @ Jul 21, 2015 - 5:11 PM) *
post Jul 21, 2015 - 10:28 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
get a multimeter and check the wires. there is a great youtube channel called Eric the car guy. he has videos on this
post Jul 21, 2015 - 11:48 PM
jcrog
Joined Mar 20, '06
thanks
QUOTE (Smaay @ Jul 21, 2015 - 11:28 PM) *
post Jul 25, 2015 - 9:45 PM
jcrog
Joined Mar 20, '06
Ok I replaced the plugs, wires, rotor and cap. Runs well but the CEL is still on. I disconnected the ECU and reconnected it as well. Any ideas??
I also removed the negative cable to try and clear the CODE. No luck still getting DTC 12.
Thanks
post Jul 26, 2015 - 9:50 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
did you check the wiring between the distributor and ECU?
the ECU is not getting the RPM signal, this is either the distributor, wiring, or the ECU
Lo-Fi Version Time is now: December 4th, 2024 - 4:31 AM
