> manually pop the fuel door?
post Jul 23, 2015 - 8:41 AM
Terzin1
Joined Feb 19, '05
From Indianapolis
In a pinch what is the quickest way to open your fuel door when the lever mechanism isn't working? Don't say use a crowbar... I don't have many tools on hand as it is.
For the best designs and screen printing.
WE DON'T PRINT UGLY.
www.TERZink.com
post Jul 23, 2015 - 10:04 AM
cheela
Joined Feb 2, '07
From Berlin, WI
if the lever isn't working, then the cable should still unlatch it. just pop your door sills off and find the cable and yank on it.
post Jul 23, 2015 - 6:04 PM
Jmk91
Joined Jan 25, '15
From United States
Orrrr your spring type thing in your gas tank lid could be broken. Happened on my Camry... Just prop the gas leaver up with something and push on the edge of the hindges of your tank lid and see if it opens. If it does than the spring thing is your issue.
post Jul 24, 2015 - 3:26 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (Jmk91 @ Jul 23, 2015 - 7:04 PM) *
This is more likely the issue unless you heard something break as you pulled it. You can use a small binder clip until you get a replacement spring
post Jul 24, 2015 - 3:36 AM
Box
Joined Feb 23, '12
From Warrior, AL
Can't remember exactly how the door works on the Celica but you should be able to slide in something like a credit card, screwdriver, or knife to push down the plunger and pull the door open.
2001 Miata LS 5-speed
post Jul 25, 2015 - 3:26 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
thats what I do. the spring on mine is wore out. and when i say spring, its really a metal tab. so i stick the credit card in the door, pull the handle and it pops open.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 25, 2015 - 3:49 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Those little springs cost like $12 from Toyota I think, they're not expensive. Honestly you can make one yourself out of an old brake clip with a pair of pliers, I've done that for customers with other kinds of cars out of kindness.
Lo-Fi Version Time is now: December 11th, 2024 - 9:02 PM
