Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) ![]() |
When you let off the gas when your driving does the car kinda bounce? It feels kinda wierd like maybe a tranny mount is broke? You gotta keep your foot on the gas alittle at all times to keep it from shaking. Does anyone elses car do this?
Enthusiast ![]() ![]() Joined Jan 16, '03 From Wichita KS Currently Offline Reputation: 0 (0%) ![]() |
ya it does it a little it just lurches a little when your on the gas and then you all of a sudden let off.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 12, '03 From Chatham, Ont Currently Offline Reputation: 0 (0%) ![]() |
When your driving in fifth, watch your shifter and let off the gas, if the shifter moves back and forth as you go on the gas and come off, then your problem is motor/transmission mount related.
![]() Enthusiast ![]() ![]() Joined Aug 14, '03 From Knoxville, TN Currently Offline Reputation: 0 (0%) ![]() |
that works in a FWD car too?
My car does the same thing but pretty bad. I'm almost sure something is broken but i cant' find it. |
Enthusiast ![]() ![]() Joined Dec 21, '03 From Houston, TX Currently Offline Reputation: 0 (0%) ![]() |
yeah mine does that but only when its like really cold outside
Alright. I think it might be normal for these cars. The tranny/motor mounts seem to be weak or something. It does do it worse when its cold too.
Celica's and the camry's also seem to have lots of engine vibration at idle which must be mount related. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) ![]() |
mine does it occasionally enough that in between times i forget it does it.
Yes, my old car did it in fifth. I dont think its a huge deal, just means you need new mounts |
Enthusiast ![]() ![]() Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) ![]() |
yah its normal.... its the way the clutch/transmission engages.... it is worse in the cold....
dont worry, just have to be good drivers in these cars, the clutch is very sensitive |
Lo-Fi Version | Time is now: February 19th, 2025 - 7:16 PM |
