Enthusiast ![]() Joined Dec 16, '02 From canada Currently Offline Reputation: 0 (0%) ![]() |
im looking for front and rear strut bars to
enhance my handling. I'm going to install the kyb's and eibach springs tmr so do u guys know whre to get the strut bars or is it simple to make em ur self. |
i bought my braces right from toyota. for the front i got the factory brace from a 94 celica, and for the rear i got the factory brace from the gt4. it cost me about 100 total.
you could probably make some yourself if you can weld. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() Joined Feb 12, '04 From Hellburbia Currently Offline Reputation: 0 (0%) ![]() |
you can make them yourself or buy from toyota, or perhaps go aftermarket and buy Whiteline strut bars, though they are quite expensive. check out whiteline's website by searching google, you own't be disappointed.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) ![]() |
Use the gt-4 rear strut bar and a corolla 93-97, from ebay, just re drill the holes for the corolla front strut bar.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
do you have some pics of those, i just got the corolla one, an just mounted it today, fine , i guess, but i would like to see what really should be on there... thanks |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) ![]() |
I'm curios about doing this, will any 93-97 corrolla strut bar work?
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) ![]() |
don't mod existing strut bars and don't buy stock ones. GAB makes them pretty cheap. check cyberspace j-speed also makes some. TRD makes a front. you have a lot of options
ok, just to let you know, that stock one, will prolly be better then any other kind you can buy, all you want is a solid peace of metal, an thats all the stock is, not a cheap $180 pos.. that wont do any more then an e-bay one, the point is, to just link the two towers togeather so they dont flex,,, therre for a solid peace of metal welded on the towers, will work better then any with a name on it...... |
Enthusiast ![]() ![]() ![]() Joined Aug 21, '03 From Endicott NY Currently Offline Reputation: 0 (0%) ![]() |
I don't call $180 bucks a piece cheap. ![]() |
Enthusiast ![]() ![]() Joined Apr 29, '03 From lynn,ma Currently Offline Reputation: 0 (0%) ![]() |
lagos, do you know the part number for the rear brace for the gt4? and how much did you get it for? thanks in advance
![]() Enthusiast ![]() ![]() ![]() Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) ![]() |
Stock bar doesnt link the two struts though...it goes to the center of the engine bay right under the winshield from both sides. Buying a full link would render greater performance.
Enthusiast ![]() Joined Nov 25, '03 From Mizzeri Currently Offline Reputation: 0 (0%) ![]() |
GT-4 Factory Rear Strut Brace:
Part # 53605-20020 |
if all you need is a solid piece of metal, how can you say that a stock one will be better than any other kind? And the type of metal makes a difference and where it sits in the bay. |
Lo-Fi Version | Time is now: February 24th, 2025 - 6:39 PM |
