> Cross drilled and sloted brake rotors and pads!
post Aug 4, 2015 - 12:40 PM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
Today I installed myCross drilled and sloted brake rotors and pads!
post Aug 4, 2015 - 1:59 PM
Jmk91
Joined Jan 25, '15
From United States
Looks good! I just have slotted on my celica. Every set of drilled rotters I've seen crack very quickly. So make sure you check them often!
post Aug 4, 2015 - 3:28 PM
doory100
Joined Jun 21, '14
crappy.. I hope mine don't do that!
This post has been edited by doory100: Aug 4, 2015 - 6:00 PM
post Aug 4, 2015 - 6:24 PM
Box
Joined Feb 23, '12
From Warrior, AL
Drilled rotors are notorious for cracking, the ones you see on high end sports cars and race cars the holes are actually cast and not drilled. As long as you don't get overly hot and then get them wet you should be ok.
2001 Miata LS 5-speed
post Aug 6, 2015 - 7:56 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
Had them on ST but never cracked
post Aug 9, 2015 - 12:33 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
My friend had a set for his mr2 for 5 years and it never cracked. Just depends on the quality and driving habits. I've had mine for a year and half with no problems.
post Aug 9, 2015 - 5:58 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
If you live in a humid place or somewhere that it rains a lot. It'll probably end up cracking eventually. If not, you'll probably be fine and they look great!
post Aug 10, 2015 - 4:21 PM
rdyzz
Joined Dec 27, '11
From minnesota
I've seen a couple drilled rotors crack also. If for performance solid blanks work the best imo, more mass and surface area is always a good thing.
Lo-Fi Version Time is now: February 22nd, 2025 - 12:24 AM
