Oxygen sensor check ? |
Aug 10, 2015 - 11:20 PM |
Enthusiast Joined Nov 29, '12 From New Zealand Currently Offline Reputation: 0 (0%) |
Hey everyone
I went to go back my celica in the garage last night and as I walked behind the car I got a strong smell of petrol :s My assumption is the O2 has gone bad (as my fuel consumption has gone up slightly) as well as idle is rough sometimes. How can I easily (and cheaply) diagnos a faulty O2 sensor ? mines a 3sfe Thanks also no CEL has come up ... Yet lol -------------------- |
Aug 10, 2015 - 11:44 PM |
you sure you're not leaking fuel or fuel vapor somewhere?
Aug 11, 2015 - 12:01 AM |
Enthusiast Joined Jan 25, '15 From United States Currently Offline Reputation: 4 (100%) |
Aug 11, 2015 - 12:30 AM |
The front O2 sensor that helps to regulate the air/fuel mixture won't throw a code unless it's completely dead. Something else that regulates the air/fuel mixture and won't throw a code unless it's dead is the coolant temperature sensor. Should be able to find testing procedures for both online.
Double check for fuel leaks as well. Other things that can cause running rich is a faulty fuel pressure regulator or leaking/sticking injectors. Won't hurt to try the reset procedure either. -------------------- 2001 Miata LS 5-speed
Aug 13, 2015 - 1:10 AM |
Hmmm have reset the fuel air mix multple times - no difference....
Decided to use the ol' fashioned paper clip trip and do a fault test.. Came up with 2 flashes. Pause. 1 flash. According to the fault code page its comes up as oxygen sensor So how many oxygen sensors are there? Is there just the one? *noob* -------------------- |
Aug 13, 2015 - 1:26 AM |
Code 21 is primary O2 sensor, so it's the one in the exhaust manifold or right below it. Which would explain the reduced economy.
Aug 13, 2015 - 1:32 AM |
Code 21 is primary O2 sensor, so it's the one in the exhaust manifold or right below it. Which would explain the reduced economy. Hmmm. The only issue i've just realised is the code i got was from http://www.6gc.net/forums/index.php?showtopic=93774 and i've realised that its OBDI - But i may have OBDII? Does that affect anything? -------------------- |
Aug 13, 2015 - 2:51 AM |
Doing the flasher check gives OBDI codes. OBDII was a U.S. only thing, I know EOBD which was Europe's equivalent wasn't until 2001, I think it was about the same for JOBD which was Japan's. Being the SS-I it was never a U.S. market car.
Aug 13, 2015 - 3:12 AM |
Doing the flasher check gives OBDI codes. OBDII was a U.S. only thing, I know EOBD which was Europe's equivalent wasn't until 2001, I think it was about the same for JOBD which was Japan's. Being the SS-I it was never a U.S. market car. Ah i see. Time to source me a new O2 sensor then... Goodbye 150 bucks Thanks Box -------------------- |
Aug 13, 2015 - 4:33 AM |
Would give eBay and Amazon a look, or any wholesale auto parts place. Not sure if RockAuto would ship to you but I think I've heard of those in Europe ordering from them before. One would think it'd use the same sensor as the 5S-FE over here but would have to double check. Something you can try before replacing the sensor is to pull it out and blast it with intake cleaner and remove all of the build-op and then put it back in one dry.
Aug 13, 2015 - 7:42 AM |
Get a sensor with the whole wire and connector, not one you wire in.
Aug 13, 2015 - 8:09 AM |
^That too.
This post has been edited by Box: Aug 13, 2015 - 8:09 AM -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: November 23rd, 2024 - 11:39 AM |
