Closed TopicStart new topic
> Front motor mount repair, actually the bolts that attach the center member
post Aug 15, 2015 - 7:09 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
The two 12mm bolts that fasten the center member to the front of the frame right here
When I first bought the car it had one of these as the proper 12mm grade 8 bolt, and the other turned out to be just a lag screw jammed in the hole.
So the threads of that hole are ruined and I am wonder if any of you guys know for sure if there is enough metal up there to just drill it out and do a standard helicoil repair?
Or am I going to have to go to more drastic measures?
Bust a Deal; Face the Wheel.
post Aug 15, 2015 - 7:18 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Should be enough metal to drill it out to a larger size and tap new threads, could use a standard bolt instead of the next metric size.
Lo-Fi Version Time is now: February 21st, 2025 - 8:14 AM
