> OEM 3rd gen 3SGE distributor vs aftermarket trigger wheel, Ignition got aftermarket ECU
post Aug 16, 2015 - 7:13 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
Hey all.
So I'm still in the process of getting parts together for my 3SGE turbo conversion.
Now my tuner friend has convinced me to go with an aftermarket 36-1 trigger wheel on the crank and Ford EDIS Coil pack.
Has anyone fitted an aftermarket trigger wheel on the crank?
Is there anyone here using a stock distributor on an aftermarket ECU? Please give me some pointers.
Cheers.
post Aug 16, 2015 - 8:33 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the only reason to use a trigger like that is for the ECU. Personally im using an AEM EMS that I made a jumper harness to work with. if the 3S-GTE and 3S-GE both have the same number of teeth in the dizzy then you can use any ECU.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: February 22nd, 2025 - 6:53 PM
